Old August 3, 2009, 10:07 PM
Default Temp Issues with Q6600 on water
I'm running @ 3.17ghz on stock everything 9x350 on a p5q pro system is stable just im worried about temps i applied thin line across heat spreaders The rad as 2 120mm 110v industrial fans pushing tons of air...I'm just lost on what to do next.. any help would be great thanks...
Old August 4, 2009, 05:24 AM
Sagath's Avatar
71c at stock volts max temp? Yeah. Something isnt right. Generally speaking you dont want to go above 65 ever, and try to keep it under 60.
I see that your Core Volts are 1.3125 in windows. (And I dont see a VID on that copy of CPU-Z...did they take it out?) Do you have to pump that much volts thru it for 3.2ghz?
Have you reseated the waterblock already? Thats always step one, and 99% of the time it is the problem too.
Old August 4, 2009, 06:56 AM
3.0charlie's Avatar
Complete system specs, BIOS settings volts-wise and wc setup definition is required to assess those temps.
Hydro-Quebec is salivating...
Old August 4, 2009, 09:08 AM
uploaded pics of bios settings
as for wc setup its ncix ultimate w/c system
pump > rad > cpu > reservoir > pump >
Old August 4, 2009, 09:17 AM
as for complete system specs
P5Q pro
Q6600 G0
gskill 1066 ram
hx1000 psu
haf 932 case
xfx 4890 gfx
gskill SSD
2 x wD 1TB Drives
win 7 RC
Old August 4, 2009, 09:30 AM
i lowered the vocore to 1.25 in bios system still stable temps still no good
Old August 4, 2009, 09:41 AM
3.0charlie's Avatar
Remount the block. Make sure you don't use too much TIM.
For 3.2, you should only need to raise the FSB. Volts are not needed (usually).
Never run Volts at Auto when oc'ing, especially the Vcore, Vram, Vfsb and Vnb. Learn your BIOS and equipment.
Ambiant temp is?
Rad setup inside case?
Old August 4, 2009, 10:10 AM
nice and cool in the house maybe 20c ish
haf 932 case rad mount inside top case blowing outward tons of air movement
remounted the heatsink 6 times yesturday small grain of rice line across heat spreaders
change vcore to 1.25v
Old August 4, 2009, 10:46 AM
3.0charlie's Avatar
Rad??? Heatspeader???
Are you water-cooling the chip, or is it Aircooled?
Can we have a clear pic of the inside of your rig?
Old August 4, 2009, 10:59 AM
hope this helps?
Core Temp Sensor issues HalifaxJ Troubleshooting 5 March 16, 2009 12:39 PM
Q6600 OC with Water stability issues gazdag6 Overclocking, Tweaking and Benchmarking 7 September 11, 2008 07:36 AM
temp issues and sli problems voklskier4452 Troubleshooting 15 June 7, 2008 09:23 PM
WTB: Decent Water Cooling System For My Q6600 saihossoku Buy/Sell & Trade 26 March 10, 2008 06:15 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
