  #21 (permalink)
Old August 4, 2009, 01:49 PM
hell yah alot of airflow lol
side panel on yes
hd's still in case
how low should i go on vcore?
  #22 (permalink)
Old August 4, 2009, 01:54 PM
water is clear as day fins are clear yes
i have never touched the fan controler its on full speed
  #23 (permalink)
Old August 4, 2009, 02:00 PM
sswilson's Avatar
Not concerned about the fan controller (unless you've got the pump plugged into it). IIRC that pump is plugged into a molex right? Have you tried a different molex on the off chance that the rail isn't providing full voltage?
Probably not any of these things, just throwing stuff out on the off chance that it's something different. It could always be that you just happened to get a Q6600 with terrible temps.
  #24 (permalink)
Old August 4, 2009, 02:02 PM
Sagath's Avatar
Until it crashes Then go up one notch in your bios.
My is stock (2.4ghz) rock solid at 1.0875v . I never run that tho, but I tried, just to see.
My last step after finding what is 'stable' (if I was just to pick an arbitrary voltage and find out it works) is to go down from there until I find my min volts.
Lots of people work their way up, with my Q6600 charlie got me to work top-down. It worked, I wasnt feeding it nearly enough volts to get to 3.6ghz. He said "Push 1.4+ and see what happens" it worked. And now its rock stable at 1.3875
Chips, like cars (and women?), can be finicky until they get what they like
  #25 (permalink)
Old August 4, 2009, 03:40 PM
well of course the pump is pumping otherwise my temps would be hella worse haha
  #26 (permalink)
Old August 4, 2009, 03:42 PM
mines stable @ 3.6ghz just the temps were in the 80's hahah so i dropped the temps but i may try lowering the voltage and see what happens
  #27 (permalink)
Old August 4, 2009, 04:47 PM
sswilson's Avatar
My point wasn't that the pump wasn't pumping, it was that perhaps the rail is only providing 9V vrs 12V which would affect the efficiency of the pump.
  #28 (permalink)
Old August 4, 2009, 05:35 PM
12.12 v i checked it with a volt meter :) ty u helped alot :)
i been priming it btw for 2 hrs now @ 3.4ghz 1.3v never goes above 60c :) im much happier now with my temps thanks alot guys
  #29 (permalink)
Old August 4, 2009, 08:24 PM
These temps should be fine?
  #30 (permalink)
Old August 4, 2009, 09:17 PM
Sagath's Avatar
What did you change? Your volts are (nearly) the same, you're at a higher clock, but now the temps have dropped 20c? You must have done something , and it had to have been pritty drastic to 'eek' out a measly 20c...
Core Temp Sensor issues HalifaxJ Troubleshooting 5 March 16, 2009 12:39 PM
Q6600 OC with Water stability issues gazdag6 Overclocking, Tweaking and Benchmarking 7 September 11, 2008 07:36 AM
temp issues and sli problems voklskier4452 Troubleshooting 15 June 7, 2008 09:23 PM
WTB: Decent Water Cooling System For My Q6600 saihossoku Buy/Sell & Trade 26 March 10, 2008 06:15 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
