Old August 4, 2009, 11:02 AM
i was talking about the cpu i applied a small rice grain amount of thermal grease mx-2 across the heat spreader on the cpu
Old August 4, 2009, 11:14 AM
3.0charlie's Avatar
Heatspreader (HSF) usually relates to an air-cooled cpu. When wc'ing, it's called a block.
Thanks for the pic; your setup should be fine for a whole lot more heat actually, with the 655 and the 120.2.
Do you know the exact room temp?
The D-Tek V1 may not be the best block for a Quad, and is very tricky to mount properly. Did you tighten the corners in an X pattern?
When you tested your Quad, was it with the side panel open, or installed? For an internal rad mount, you need a great deal of cool air - and with 4 HDDs it doesn't help.
Hydro-Quebec is salivating...
Old August 4, 2009, 11:26 AM
20c in room
side panel always closed
there isnt alot of hot air comming from the case... these fans im running on the rad are
ebm-papst St. Georgen GmbH & Co. KG
Type 4606 N
Nominal voltage [VAC] 115
Frequency [Hz] 60
Speed [min-1] 3100
Power input [W] 18.0
Min. ambient temperature [C] -40
Max. ambient temperature [C] 90
Air flow [m3/h] 180
Sound power level [b] 5.8
Sound pressure level [dB(A)] 51
i find my qx9650 was alot cooler with this same setup :\
i guess ill just go buy a q8400 45nm since it will drop the temps :|
would as5 make a difference?
Old August 4, 2009, 11:38 AM
3.0charlie's Avatar
AS5 would make a difference, but not that much.
Run stock speed, stock volts. What are the temps at idle and under load (Prime95, 100% load), with and without the side panel. I'm tempted to say you do not have enough airflow in the case.
Old August 4, 2009, 11:44 AM
Sagath's Avatar
I'm going to agree with Charlie here. Do you have the side fan running too? From your picture it looks like the rear fan isnt running, and the front fan is hella-blocked by the 4 hard drives. Not to mention 1000w PS's create some good head inside a case, plus that 4890...
I would guess you have a negative case airflow, since the only fans actually doing anything are your two rad fans. Thats alot of hot air blowing across your rad. Try hooking up that massive side panel fan, moving some Hard drives (you only list 2, but there is clearly 4), and see if it helps?
An inline temp reading would probably solve this problem right quick.
Old August 4, 2009, 11:57 AM
yes fans are on fully i can remove all the hd's and do the test not a big deal the psu heat runs out threw bottom of the case...these are the new tests i ran with latest voltage drop better?
Old August 4, 2009, 12:00 PM
3.0charlie's Avatar
Much better - and remember that you are using IBT to test, which personally is overkill. Those temps look inline with that app. Try Prime95, latest version. Again, with and without side panel.
Heck, drop the Vcore even more...
Old August 4, 2009, 01:10 PM
how about now?
  #19 (permalink)
Old August 4, 2009, 01:17 PM
3.0charlie's Avatar
Getting better - with, or without side panel? Also, see if you can lower the Vcore more.
  #20 (permalink)
Old August 4, 2009, 01:25 PM
sswilson's Avatar
Something still doesn't seem right here....
What's your airflow up top like? Can you feel the air from those beastly fans blowing up through the top of your case?
If not, is it possible that the fins of your rad need a good cleaning? How about the internals of your block? Any chance it hasn't been cleaned in quite some time and has an algae buildup?
edit: What about the pump? Any chance you've started controlling the speed of it recently and it's not moving as much water as it used to?
Core Temp Sensor issues HalifaxJ Troubleshooting 5 March 16, 2009 12:39 PM
Q6600 OC with Water stability issues gazdag6 Overclocking, Tweaking and Benchmarking 7 September 11, 2008 07:36 AM
temp issues and sli problems voklskier4452 Troubleshooting 15 June 7, 2008 09:23 PM
WTB: Decent Water Cooling System For My Q6600 saihossoku Buy/Sell & Trade 26 March 10, 2008 06:15 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
