Old August 3, 2009, 01:59 PM
Cowboy's Avatar
Default Sub zero cooling prep
Hey,
What Kind of motherboard protection do you use whenever you go sub zero? Or even cold enough to create condensation?
Old August 3, 2009, 02:02 PM
CMetaphor's Avatar
Quadfather
Sub-zero automatically means there Will be condensation, no matter what. I believe most people use insolation foam on their motherboards or rubberized erasers (the type you can pull apart easily) to prevent moisture from building up.
Old August 3, 2009, 02:06 PM
bissa's Avatar
live at the north pole or somewhere where the temprature will never go above the temprature that you are cooling at and keep your case outside. tada no condensation.
Strong like hummingbird, swift like oak.
Old August 3, 2009, 02:41 PM
Cowboy's Avatar
If you've got nothing useful to say, keep it to yourself.
@ Colourful Metaphor:
I know there will be condensation, I just didn't know how to phrase my question.
I wanted to know what people used to protect their motherboards from phase change and LN2 because I'm going to be dabbling in it fairly soon.
Old August 3, 2009, 02:52 PM
CMetaphor's Avatar
Quadfather
With phase change you should have enough control over the temperature to prevent condensation. That being said, it doesnt hurt to be careful
Old August 3, 2009, 03:08 PM
Cowboy's Avatar
Ok so just kneaded eraser then?
Old August 3, 2009, 03:17 PM
CMetaphor's Avatar
Quadfather
I'd say you wouldn't need more. Just be sure to cover everything around the CPU socket well - we'd hate to see you fry something from a stray drop of water condensing on a vrm or similar, hehe.
Old August 3, 2009, 03:19 PM
Cowboy's Avatar
no vaseline in the cpu socket?
Old August 3, 2009, 03:26 PM
CMetaphor's Avatar
Quadfather
IN? Don't recall ever seeing that... I have heard of sealing the outside edge of the CPU socket Very Well. But beyond that... perhaps we should ask 3oh6!
Old August 3, 2009, 03:38 PM
Lpfan4ever's Avatar
I was about to say, I have about as much knowledge of this as I do in speaking any other language than English. However, if 3oh6 doesn't see this, send him a PM and I'm sure he'll share is plethora of sub-zero knowledge.
Originally Posted by encorp
Code:
<firebane> slightly used
Enough Cooling? Justin Cider Water Cooling 14 June 26, 2009 03:17 PM
NB Cooling - What would you do? biff Water Cooling 18 April 21, 2008 08:48 AM
NB Cooling.. Infiniti Water Cooling 7 April 15, 2008 06:36 PM
Cooling NB jnliten CPU's and Motherboards 6 March 29, 2008 06:31 PM
How is my cooling? mattydies Water Cooling 6 August 9, 2007 08:12 AM
