Old August 1, 2009, 03:06 PM
Default Are these temps ok for an E8400?
Recently I over-clocked my E8400 (it's my frist time overclocking) and it's idle temp is 30-35C and load is 50-50C is this a "safe" or good temp for the E8400? It's running at 3.6GHZ but I am only using a mid stream heat sink (I do plan to upgrade it....eventualy).
Thanks
Old August 1, 2009, 03:55 PM
misterlarry's Avatar
I would say that those are OK temps. Mine runs at average 42C while folding (BOINC). My cpu use to run about 5-6 degrees hotter before I put the passive cooler on my video card.
Asus Z97-A - Intel i7 4790K @ 4.0 GHz - Corsair H80 CPU Cooler- 4x8 GB G.Skill Ares DDR3 2400 - EVGA GTX960 4GB
1x240 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 1X2 TB Western Digital Green - Pioneer DVR-212D - Antec P182 - Rosewill Photon 850 - 2X24" Acer G246HYL - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old August 1, 2009, 03:58 PM
sswilson's Avatar
IMO, 50c is fine under load.
Old August 1, 2009, 04:01 PM
Mine that i just overclocked to the same speed (3.6) runs at 36C idle and 48C load. Using a Xigmatek HDT-S1283 with a bolt kit and AC MX-2 paste. Was hoping for a bit cooler :\
Old August 1, 2009, 04:07 PM
sswilson's Avatar
Keep in mind that temps at this time of the year are greatly affected by ambient temperatures, especially with air cooling.
Old August 1, 2009, 04:37 PM
28.5 C in here right now
Old August 1, 2009, 06:24 PM
I thought that I would post this here cause it all relates without opening a new topic hopfully someone will reply so I dont have to but, how many passes of MEM test do you guys run before you consider your ram timings and such stable?
Old August 1, 2009, 06:45 PM
MonsterSound's Avatar
I usually go for ~ 12 hours, but that's when you think you have set up the overclock you want and expect it to be stable.
p.s 50c is perfectly fine for the E8400 with a mid-range cooler under load.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old August 1, 2009, 07:43 PM
DrPepper's Avatar
You live in a toaster? My house is always around 17C.
Old August 1, 2009, 07:47 PM
Arinoth's Avatar
Man that must be nice and rather expensive on the hydro bill at the same time. I think i'm in the basement and it doesn't get that cool in the summer even with the air conditioning on
Here I am: here I remain
E8400 Idle temps? Realityshift Air Cooling 12 May 23, 2009 01:58 PM
Temps for E8400 on W/C clearly off... Barber Water Cooling 18 April 6, 2009 10:02 AM
E8400 temps miggs78 CPU's and Motherboards 14 September 8, 2008 05:36 PM
E8400 Core temps - OCZ Vendetta 2 cooling Dwayne Air Cooling 8 August 17, 2008 01:13 PM
E8400 Idle Temps... rjbarker Overclocking, Tweaking and Benchmarking 13 April 14, 2008 02:36 PM
