Old July 30, 2009, 09:09 AM
Default OC E8400 on P5QL
All the manuals for OCing on the net are for P5QL PRO.
This is my first overclock so i wanna make sure i dont mess anything up.
I found this: (for P5QL pro)
Under AI Tweaker Menu
Set FSB Frequency to 400mhz
Set PCIE Frequency to 100
Set FSB Strap to Northbridge to 400mhz
Set DRAM frequency to 400mhz
DRAM = Memory
Now i cant find FSB Frequency
Cant find PCIE frequency
Found FSB Strap to Northbridge
DRAM frequency - it (BIOS) says if i put it under 667, it may result as a boot up failure.
So any help would be welcome.
And yes i know i also have to change voltages.
Ok i just found out that the 2 BIOSes are different.
Okay EVERYBODY has Pro or P5QL-E so im hopeless!
I have no idea how to overclock with P5QL
Im utterly shocked about how left out this mobo is.
Okay i could overclock, but after the exit bios restart my PC wouldnt boot into windows and said i have to insert Windows CD and repair windows... sup with that?
So i changed back to stock settings and it booted right away.
Old July 30, 2009, 10:43 AM
Okay i managed to overclock this thread can be closed.
Still im amazed by the lack of support for P5QL
Guides for Overclocking E8400 w P5QL Pro mb inf3kt Overclocking, Tweaking and Benchmarking 18 November 11, 2008 02:15 PM
LF--E8400 Gunner86 Buy/Sell & Trade 3 October 19, 2008 03:04 PM
E8400 on ? Rapid-X CPU's and Motherboards 7 May 9, 2008 03:31 PM
are the E8400 out yet? v0maru CPU's and Motherboards 4 March 31, 2008 09:56 AM
