Old August 2, 2007, 02:30 PM
sswilson's Avatar
Super Moderator
Default Before & After
Thought it might be interesting to have a spot to drop quick and dirty comparison results from new upgrades / drivers.
Nothing fancy, but it would give folks a chance to see what kind of real world results they might expect if they are looking at a particular piece of hardware / new driver.
Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW
ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF
Old August 2, 2007, 02:36 PM
sswilson's Avatar
Super Moderator
Just replaced a stock intel cooler with an A-C Freezer 7 Pro. Still using stock tim from it, and it's just been installed so no break in period......
Load temps (18 minutes orthos E6600 @ 3200 1.48V)
Stock intel - CPU-56c / NB-23c / System-20c / HD-20c / Core1-62c / Core2-62c
Freezer 7 Pro - CPU-48c / NB-23C / System-20C / HD-20C / Core1-55C / Core2-55C
I'm pretty impressed, this is just about the cheapest aftermarket cooler around (that works.... :) ), and it snaps into the motherboard without needing any backplate.....
Old August 2, 2007, 06:46 PM
sswilson's Avatar
Super Moderator
5 hour break-in and I'm now running same temps (49 / 55 / 55) @ 3380 1.52V after 1 hr Orthos.
You can colour me impressed with a $27 aftermarket cooler..... :)
Old August 2, 2007, 08:28 PM
Misoprostol
Guest
Posts: n/a
The Freezer 7 is a great little cooler. And the price is certainly right :)
Old August 2, 2007, 08:35 PM
Level up: 8% Level up: 8% Level up: 8%
Level: 23 - 1,381 points to level up
Too many people figure they need to spend $50 on a massive cooler to get a decent result for a cooler but in retrospect you can spend $25 and get one that works better and more efficient than the stock cooler.
Old August 3, 2007, 09:52 AM
Mibs's Avatar
Level up: 45% Level up: 45% Level up: 45%
Level: 12 - 226 points to level up
Just upgraded from a 3.06GHz P4 to a C2D E6750 right now at stock speeds. SuperPi Calculation of 4Million used to take 4+ minutes. Now it takes 1:50.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 2 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Old August 3, 2007, 10:25 AM
sswilson's Avatar
Super Moderator
Heh.... and that's only using half of the processing power of each core.... :)
What's your 1M super-pi score?
Old August 3, 2007, 10:57 AM
Mibs's Avatar
Current high score for 1M is 19.172s. It's like night and day when comparing this chip to that P4!
EDIT:
After a 13% overclock to 3.0 GHz 1M score is now 17.079s. 2 seconds less, woot!
