Old July 23, 2009, 07:08 AM
jcmaz's Avatar
couldn't you use that SetFSB on generic computers like D3LL???
-Plato
Old July 23, 2009, 09:37 AM
burebista's Avatar
Originally Posted by enaberif View Post
Software = garbage.
And BIOS is hardware?
Old July 23, 2009, 11:35 AM
gingerbee's Avatar
Good point i think they mean manually manipulation
Old July 23, 2009, 05:00 PM
mattydies's Avatar
I know that bios is "the only way to go" BUTTTTT MY bios is messed up REALLY good. It takes between 1 and 13 tries to get it to post.
SetFSB has no support for my board. Oh well, thanks anyways.
Once in a blue moon it boots the first time and accepts my overclocking settings - This happened yesterday. I plan to avoid shutting down at all costs
For now I am running @ 2.81ghz with my ram running @ 694Mhz. 4-4-4-10~1T (Instead of 677, 5-5-5-15 [2t?] which it is normally stuck at).
It seems I am destined to wait for the new Mobo for overclocking.
My mobo may have included software, I may look into this if I have to shut down before I get the new board
CPU and Memory testing software Wolfx25 O/S's, Drivers & General Software 5 June 8, 2009 08:45 AM
Eq Software? aviduser Audio 2 May 6, 2009 10:55 AM
Tax Software misterlarry O/S's, Drivers & General Software 18 April 16, 2009 08:51 AM
Software WolfBane Networking 11 August 1, 2008 12:28 PM
