Hello, I'm new here. I have googled around but could not find a solution to my problem, so I hope maybe someone here could give me some advice... thanks! So, as the topic says, I'm using a C2D E6300 on a Gigabyte 965P DS3 3.3 (F12) mobo. Ram is 2GB OCZ Platinum Rev.2 PC-6400, EVGA 8800GTS 640mb for video card, and Vista 32bit. I've had this build for about 4 months now. Right now, I have my E6300 running at 3.01ghz (430x7). I had to set the PCI-e frequency to 105 in the BIOS and +0.1 volts to PCI-e in order for PCI-e to run at x16; otherwise, it would be running at x1. I have been trying to oc it to 3.2ghz, and the only problem I have now is that the PCI-e stays x1 when I set the PCI-e frequency up to 110 in the BIOS. Does anyone know how I can get to 3.2ghz while maintaining the PCI-e speed at x16? Thanks in advance! Last edited by h0nam; July 30, 2007 at 12:13 PM. |
Thanks for your reply! There is a feature to set my PCI-e frequency; the problem is, when I lock it at 100, the PCI-e bus runs at x1 speed instead of x16. It seems that the higher the FSB, the higher the PCI-e frequency needs to be adjusted in order to keep it at x16. I've heard that this may damage the video card though, and so I am no going to try anything above 110 for PCI-e frequency... that's why I was wondering if there was any other way to make it work properly.
yeah its a known problem on dfi p965-s boards so probably others too.. did you try every setting between 100-110? or maybe lower?
__________________ Q6600 G0 @ 3.2ghz (965 chipset holding me back) DFI Infinity P965-S Gigabyte Geforce 8500GT Buffalo Firestix FSX800D2C-K2G 2X1GB PC2-6400 CL5 OCZ XTC Active Memory Cooler Seagate Barracuda 250GB SATA2 MCE Wireless Keyboard / Remote Logitech X-530 Speakers Swiftech H20-220 Water kit Swiftech MCW30 NB Cooling OCZ PowerStream 600W |
Hey thanks for the replies, but I got everything worked out... sort of. It turns out that I needed to +0.1v to the MCH thing... although I'm really not sure what that is... This way, I could have my PCI-e locked at 100 and still have it running at x16. The only problem now is that I am overclocking my E6300 to 3.2ghz with the vcore at 1.45v, which I would consider extremely high, especially for a C2D. Right now I have it Orthos stable for 13 hours, but anything below 1.45v it becomes unstable. |
| Quote:
as long as your temps are good you shouldn't have any trouble running 24/7
| Quote:
My settings on my DS3 rev3.3 (on the old F10 BIOS) MCH +0.1V FSB forced to 100MHZ FSB +0.1V CPU 1.375V RAM 1:1 @400FSB stock volts
__________________ E6420@3.2Ghz/ Gigabyte P965-DS3 Rev.3.3 F10 Bios/2 Gigs Mushkin EM-PC6400/Arctic Cooling Freezer 7/GeForce 8800 GTS 640Mb SC 651Mhz-2020Mhz/Antec TP3 650W/Thermaltake Armor Jr./Seagate 160G/WD 250G/Audigy 2ZS/Logitech Z-2200 3DMarks06 (12223 pts) |
| Quote:
1.45v is fine, I wouldnt worry about it. :)
__________________ Hockey Mod at your service |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| GA-965P-DS3 Bios 11 ? Any luck? | Delavan | CPU's and Motherboards | 0 | May 30, 2007 05:40 AM |
| GA-965P-DS3 .. is revision 3.3 important? | mbolduc | CPU's and Motherboards | 3 | May 27, 2007 09:48 AM |
| e6850 at 500 fsb on Gigabyte GA-965P DS3 | Babrbarossa | Overclocking, Tweaking and Benchmarking | 2 | March 17, 2007 11:05 AM |
| TweakTown reviews the Gigabyte 965P-DQ6 Rev 3.3 Motherboard | Babrbarossa | Reviews & Articles from the Web | 0 | February 12, 2007 06:51 PM |
| TechSpot stages Core 2 E4300 vs. E6300 overclocking battle | Supergrover | Reviews & Articles from the Web | 5 | January 25, 2007 02:49 PM |
