Old July 27, 2007, 01:44 AM
Default AMD Athlon 64 X2 4200+ Overclocking
Hi, I was just wondering if anybody could give me some advice or help with overclocking this cpu. I recently overclocked my gpu and now want to do the next in line. Heres my specs:
ASUS M2N-E SLI
Mushkin EM2-6400 DDR2 (2x512)
eVGA e-Geforce 7900 GS KO
Ive done some reading and seen that this particular proc runs very stable up to 2650 Mhz but after that it starts using alot more voltage and the temp increases quickly. Any help would be appreciated. Thanks
Old July 27, 2007, 10:52 AM
Patriote's Avatar
Level up: 10% Level up: 10% Level up: 10%
Level: 17 - 721 points to level up
Hi savey421
May i suggest you to read some overclocking guides before going into Ocing ?
Overclocking isn't that simple. I mean if you have no clues what the heck your doing... Then you'll end up screwing everything... Basically, you must learn the basic words, feature of mobos etc... Once you know them, it'll be easy.
I could always give you straight steps to achieve 2.6Ghz but you woudn't learn.
Here, check out this post : http://www.hardwarecanucks.com/11222-post7.html (Whole thread : Overclocking Guides )
BTW: Welcome to Hardwarecanucks.com!
• - EVGA 680I A1
• - QX6800ES G0 @ 3.95Ghz
• - SLI BFG 8800GTX @ 626Mhz \ 2000Mhz
• - 4GB G.SKILL F2-6400PHU2-HZ @ 1000Mhz
• - Ultra X3 1000 Watt
• - X-FI XtremeMusic \ Klipsch Promedia 2.1 THX
• - WD RaptorX 150GB \ WD500GB \ WD Caviar 250GB
• - MountainMod U2-UFO Black Powder Coat
• - Dell UltraSharp 24''
Loop #1 : D-Tek FuZion - 2x MCW30 - Cyclone Res - MCP355 w/ Petra's Top - PA120.3 - Tygon
Loop #2 : 2x Ek-FC 8800GTX - Ek 150 Rev.2 - MCP355 w/ Petra's Top - PA120.2 - Tygon
Need a good mobo to overclock my 4200+ Scart CPU's and Motherboards 5 March 15, 2008 01:24 PM
Overclocking Athlon 3800+ X2 vdf22 Overclocking, Tweaking and Benchmarking 5 February 7, 2008 02:25 PM
Using AS5 on Amd X2 4200 Dashock Overclocking, Tweaking and Benchmarking 0 January 8, 2008 10:15 AM
Help Overclocking the Amd X2 4200 939 Dashock Troubleshooting 5 January 1, 2008 12:24 PM
AM2 4200 vs. e6600? ragenrok CPU's and Motherboards 28 May 4, 2007 04:14 PM
