Old July 26, 2007, 11:58 PM
Level up: 13% Level up: 13% Level up: 13%
Level: 17 - 692 points to level up
13500 does seem pretty low. If I can score ~11000 with the stuff in my sig, that's not much of an increase consider he has 2 much more powerful cards, and a Quad-Core CPU as well.
I've seen single 8800GTX setups score 13500...
BTW, are you referring to the 8800GTX or 8800GTS. You just state GT which does not exist.
Xeon Quad X3350 | 3.40GHz (Damn X38 chipset)
ASUS Maximus Formula | BIOS RF0410
2GB Corsair Dominator | 850MHz
4-4-4-12-2T
2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T
HIS ICEQ4 Turbo HD4850 @ 700/1200
X-Fi XtremeMusic
Antec TruePower Quattro 850W
Antec 900
[ HEATWARE ]
Old July 27, 2007, 06:56 AM
magictorch's Avatar
Level up: 9% Level up: 9% Level up: 9%
Level: 18 - 804 points to level up
Default its 8800GTX sorry!
I thought SLI would make more of difference-still think his scores a bit low given what single cards and dual cores can achieve. anyway the physics card is not being used for games it is used for "modelling". the computer works fine for its "working jobs" but needs to be optimised. anyway thanks for your feedback.....
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black).
Loop 1: MCR 220 int. ; Apogee GT block.
Loop 2: MCR 320; Swiftech Res.;
2x EK FC blocks.
Pumps: 2x MCP655.
Old July 27, 2007, 09:16 AM
Level up: 8% Level up: 8% Level up: 8%
Level: 23 - 1,381 points to level up
I'm pretty sure most people use 3d Mark 05 when it comes time to benchmarking due to less restrictions on a video card.
Old July 27, 2007, 10:23 AM
magictorch's Avatar
Default ill see if i can get his 05 score later on
He was working on the rigs SLI... before his deployment to a nasty hot dry place but wont be back till the fall..hed asked me to look for suggestions here as he wasnt happy with the striker board ...im not sure about the whole SLI thing myself--shame they dont just concentrate on making one really good card, instead of encouraging buying pairs.
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
2x EK FC blocks.
Pumps: 2x MCP655.
Maximus Extreme SagManQc CPU's and Motherboards 35 December 21, 2007 08:15 PM
Ram overclocking with 680i and QX6700 Friedchicken Overclocking, Tweaking and Benchmarking 2 May 31, 2007 10:43 AM
Vista + QX6700 = 50% OC sizerkozak CPU's and Motherboards 8 February 18, 2007 06:24 AM
Quad Cores are official: Core 2 Extreme QX6700 UNESCO CPU's and Motherboards 2 November 5, 2006 09:49 PM
