I don't know how long this link will stay active so if someone can possibly dump it somewhere where it'll stay safe I'll say do it. This version of Prime95 I find works better than Orthos and allows multiple cores in one instance instead of needing 2 or 3. I haven't tested it with a quad core yet so I don't know if it recognizes 4 cores, but it works awesome with 2. http://starostise.free.fr/overclocking/soft/p95v251.zip |
That is pretty nice. Seems to work fine. Both my cores are at 100%. Mirror on MediaFire: p95v251.zip Should stay up forever...
__________________ Xeon Quad X3350 | 3.40GHz (Damn X38 chipset) ASUS Maximus Formula | BIOS RF0410 2GB Corsair Dominator | 850MHz 4-4-4-12-2T 2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T HIS ICEQ4 Turbo HD4850 @ 700/1200 X-Fi XtremeMusic Antec TruePower Quattro 850W Antec 900 [ HEATWARE ] |
Most current version of P95 is v253. This version has a new version of the prime factoring runtime that apparantly deals with an issue with Core2 cpus. I've attached it here. |
Works the same. Newer must equal better! Quote:
| Thread Tools | |
| Display Modes | |
