Old July 16, 2009, 04:08 AM
Apathetik's Avatar
Post Overclock & Voltage on Xeon 3350
I have my Intel Xeon 3350 currently @ 3.5 GHz and @ 1.37 V
Question is, does this seem to be too high of a voltage to be running 24/7? The temps in the evening and night time are right around 28-32c, and in the day time around 34-37c idle.
Thank you :)
Old July 16, 2009, 04:34 AM
gingerbee's Avatar
load temp is all that matter's
Old July 16, 2009, 09:02 AM
JD JD is offline
Seems like a lot of voltage for 3.5GHz...
My X3350 runs 3.4GHz with 1.22V.
Old July 16, 2009, 01:12 PM
Apathetik's Avatar
I've tried lower, and it won't run. 100% load temps were in the low to mid 60s. In game, it gets up to about 45c in day time, and about 40c at night. Is this a problem? Will that much voltage running thru it all day long 24/7 burn the chip out? Or is it still within reason that the temps are average.
Old July 16, 2009, 02:48 PM
gingerbee's Avatar
i have run many a chip at there max voltage there whole life. and never had any problems
( I consider the life of a chip to be 6 to 8 years at most)
Old July 16, 2009, 07:03 PM
Apathetik's Avatar
Awesome! Thanks gingerbee. Nice pic btw lol.
Old July 16, 2009, 07:12 PM
gingerbee's Avatar
pic do you mean the avatar thank
Old July 16, 2009, 08:09 PM
JD JD is offline
I'm curious, have you tried increasing the NB and FSB voltages instead while lowering the CPU voltage? Typically 45nm quads need a bit more FSB voltage rather than cranking the CPU voltage high.
Old July 16, 2009, 09:22 PM
Apathetik's Avatar
Which one would be the northbridge voltage on a 780 board?
Heres an identical pic of my bios
Old July 16, 2009, 09:24 PM
Apathetik's Avatar
Thanks for your guys help too. I appreciate it immensely.
I also seen some guide of a guy who got a Blue Ribbon and said to change all those lanes to +85 or +90 then to see how it runs. I just left those all on auto though and it ran stress test for 2 hours.
http://img291.imageshack.us/img291/5...yoverclock.jpg
Xeon Overclock & Voltage Apathetik Air Cooling 3 January 6, 2009 09:59 PM
[FS] Xeon E3110 Sniper Buy/Sell & Trade 5 November 27, 2008 06:24 PM
How well does the XEON 3070 Overclock in general? bushwickbill CPU's and Motherboards 1 July 21, 2008 11:09 AM
New Xeon vs Q6600 Nodscene CPU's and Motherboards 4 April 1, 2008 03:16 PM
xeon Rapid-X CPU's and Motherboards 17 March 9, 2008 05:07 AM
