Old July 14, 2009, 04:26 AM
Default Silly Question
When overclocking - can the OS and hard drive firmware make any difference to your overclock?
I hadn't thought so, but the reason I'm asking is that when I had previoiusly been overclocking my Q9550, I seemed to max out at about 3.83GHz without touching the voltages, and not with much stability. Now... instead of Vista, I'm running Windows 7, and I updated the firmware on my Seagate hard drive - and I'm overclocked at 3.98GHz - and while I haven't done much, it at least appears to be stable.
I'll be bringing it back down to around 3.4 where I normally like to run - but thought this was an opportunity for the overclocking veterans to educate me.
Old July 19, 2009, 10:57 PM
clone63's Avatar
Looks like the vets don't know, me included (amateur at best).
Old July 19, 2009, 10:58 PM
Arinoth's Avatar
To my knowledge i don't think the OS and hard drive firmware should make a difference since its all motherboard/cpu/memory side and has nothing to do with the SATA or PATA buses
Here I am: here I remain
Old July 19, 2009, 11:49 PM
Correct.
Neither hard drive OR OS will make any negligible difference on a overclock.
Only things that will is power supply, ram, and motherboard.
silly question? dadzilla Video Cards 10 May 18, 2009 01:15 PM
I'm going to try something silly... Dr_BenD_over Video Cards 7 October 1, 2008 05:39 PM
