Old July 24, 2007, 07:35 AM
Rapid-X's Avatar
Level up: 85% Level up: 85% Level up: 85%
Level: 12 - 63 points to level up
Default help
im looking to overclock this system:
elitegroup C51GM-M
nvidia 7900gt oc pci-e
amd 4800+ 2.5 dual core
200 gig sata2 harddrive
2 gig crosshair ram
pioneer dvd burner
pioneer dvd burner
5x 80mm led fans
harddrive cooler
pci exhaust fan
450 watt coolmaster power-supply
...Is there a program i can use to overclock the cpu cause my bios only overclocks the volts. and i want to overclock the ram and video card too. i know fir the card i can use the nvidia tool but wat about the ram and stuff????
Old July 24, 2007, 07:54 AM
Cheator's Avatar
Level up: 37% Level up: 37% Level up: 37%
Level: 14 - 368 points to level up
elitegroup C51GM-M
2 gig crosshair ram
pioneer dvd burner
pioneer dvd burner
5x 80mm led fans
harddrive cooler
pci exhaust fan
You can use clockgen to overclock your ram and CPU and change the dividers, but dont expect alot from that setup. The PSU is a little low for mega overclocking and the board doesn't overclock THAT much.
Make sure you watch if your PCI clock is locked or not when you increase the speed. If it isn't, it can corupt your hard drive, potentially.
Optimus: Antec P180, Asus P5Q-E, E8400, 4 GB RAM, Asus 4850, Seagate 320gb, Antec TC II
Teletraan I: Asus P5K-E/WIFI, E4500, 2 GB RAM, ATI 3450, Sapphire Theatrix, 2.25TB storage, Antec SP2 400w
Galvatron: Asus M2NPV-VM, 3800+ X2, 2GB RAM, NV8500GT, Seasonic 500w
Tracks: Acer AS5920, C2D 2.1ghz 45nm, 3GB DDR2, NV8600m GT, 250gb hdd
Hound: Gigabyte GA-MA74GM-S, AMD 4400+ X2, 1 GB RAM, 2900XT, 500w Seasonic
My Heatware!
| Got RMA? Tell us your experience! | VOIP Help? PM ME!
Old July 24, 2007, 01:14 PM
Rapid-X's Avatar
Default im lost lol
so u mean i should make sure the clock is locked?? how can i test or see if my board is avaliable in this clockgen program?
