Old July 23, 2007, 10:00 AM
Default E6600 with D975XBX2...
I am building another computer. I installed a Intel E6600 on the XBX2. The BIOS is to date. I notice that I can't change the multiplicator (stay in gray shade) and it is stock at 9!!!
I was able to increase the FSB to 334 and run stable and cool at 2997MHz (with Corsair Twin 667MHz). I will like to increase the multiplicator to 10! Is there a way to do this (or how to enable this comand in BIOS)?
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
Old July 23, 2007, 10:32 AM
JD JD is offline
It's impossible. The multiple is locked an all Intel Core 2 Duos except for the "Extreme" edition ones like the X6800.
New E6600 don't overclock as well as the older ones apparently. My "older" one can do 400x9 = 3.6GHz with 1.45V.
Old July 24, 2007, 07:20 AM
...good to know! Thank you.
...I am use to the QX6700!
Old July 24, 2007, 11:45 AM
Babrbarossa's Avatar
I've been wondering how the newer cheapo q6600s are doing- I have been considering getting one, but I had a feeling that I couldn't expect much OC from them. Anyone else bought one lately?
psst, wanna see my binder?
Old July 24, 2007, 04:33 PM
that's not true at all. my e6600 allows for multipliers 6-9 to be used. currently running 400x8.
francois, i'm not familiar at all with that mobo but a quick google search should help you out.
ASUS P6T
Intel i7 920 @ 3.8GHz w/ 1.35v
3 x 2048MB PC3 12800 OCZ Platinum XTC @ 1528MHz (7-7-7-20) w/ 1.6v
2 x Sapphire HD 4870 1GB
SoundBlaster X-Fi Platinum
2 x WD1500ADFD RAID 0
4 x WD5000AAKS RAID 0+1
Tt Armor Aluminum Tower
Enermax Galaxy 1000W DXX
DELL 2405FPW, 1905FPW
Old August 14, 2007, 11:08 AM
Supertim0r's Avatar
you can't change the multi on non XE C2D
you can change it on quad Q6600/QX67/68/6850
Old August 14, 2007, 03:25 PM
if you're disputing me, you're wrong. you can change the multi on ANY C2D or Quad. you just can't raise the multi unless you have a X model.
ASUS P6T
Old August 14, 2007, 05:50 PM
Supertim0r's Avatar
on the XBX2...
Old August 14, 2007, 07:47 PM
all c2ds can be downclocked not upclocked unless the board won't let you.
Old August 14, 2007, 08:35 PM
on the XBX2...
ok np.
ASUS P6T
Intel D975XBX2 and 8800GTX = bottleneck? Dooobie CPU's and Motherboards 11 October 11, 2007 12:46 AM
D975XBX2 can't boot after FSB increase francois methot Troubleshooting 6 April 14, 2007 01:57 PM
e6600 p5b help plz... razor4life CPU's and Motherboards 14 April 7, 2007 12:32 AM
Intel D975XBX2 vs. the ASUS P5B deluxe….P965 vs. 975X philmar CPU's and Motherboards 51 March 28, 2007 04:12 PM
Motherboards.org reviews Intel D975XBX2 (BadAxe) Supergrover Reviews & Articles from the Web 0 January 25, 2007 06:49 AM
