Old July 9, 2009, 07:08 PM
SEVEN's Avatar
Default Help overclocking i7
My current build, below, will work fine for now however I was wandering what the best motherboard would be if I wanted to overclock down the road. Is the EVGA SLI LE that I listed a good overclocking board for the i7?
I'm currently using the computer for lots of multitasking and occasional gamming.
I know there are better motherboards to overclock the i7 but I'm looking at a price range of 200 to 300 dollars(Nova Scotia, Canada).
Build(this build not yet ordered working on it it's my new build):
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
XFX HD-487A-ZHFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
PC Power & Cooling Silencer PPCS750QBL 750W ATX12V / EPS12V SLI NVIDIA SLI Certified CrossFire Ready 80 PLUS Certified Active ... - Retail
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3P1600LV6GK - Retail
EVGA 141-BL-E757-TR LGA 1366 Intel X58 ATX X58 SLI LE Intel Motherboard - Retail
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
Thanks for the help. Also I'm new and reviews on this site are great
Old July 9, 2009, 07:19 PM
gingerbee's Avatar
yes yes
Old July 9, 2009, 08:02 PM
SEVEN's Avatar
Default Elaborate
Anyone care to elaborate on how good the motherboard would be for overclocking?
Is it very good anyone know a possible range?
I just want to make sure itís a good choice and I donít have a lot of knowledge about overclocking with the i7
Thanks for the reply gingerbee.
Old July 9, 2009, 10:04 PM
rjbarker's Avatar
Yes its a good Board...likley be able to push a DO Stepping 920 CPU to 4 Ghz...no guarentees though!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old July 10, 2009, 04:37 AM
bojangles's Avatar
Just remember that that's a TR board, meaning you don't get the lifetime warranty that's usually associated with EVGA. Just remember to find an A1 series if it really matter to you.
Old July 18, 2009, 06:17 PM
i agree, AI series should be strongly considered. as OCing stresses your hardware. as flaws would show up in the form of exploding resistors or caps. or just excessively hot chips on the board. be sure to register within the said 30 days i believe. Most ex58 boards are fairly good for OCing, some are better than others, by a small albeit noticeable margin.
i'm using the asus p6t now, previously had the deluxe version. I do miss the SAS controller...:(
just got it watercooled and running. will try and oc.
Old July 18, 2009, 07:35 PM
redgarl's Avatar
You should check Tomshardware 955 review. if you only plan to put a single 4870, a core i7 will actually underperform a simple Phenom II X3.
You need at least 2 4870 to really see a difference. There is a review on Hard OCP comparing a Q96XX, i7 920, X4 and X3. I don't think the difference between a X3 and a i7 worth the 300$+ more, but your money your way.
Phenom II X3 720 BE (4th core unleashed and underclock at 1.2375V) --> X4 @ 3.6 GHz
OCZ Vendetta 2 cooler (CoreTemp 23C @ idle)
OCZ OCZ3P16004GK DDR3 @ 1600
Asus M4A78T-E
HIS 6850 in crossfire (OC @ 840 MHz)
OCZ Fatal1ty 750 W
Coolermaster Cosmos S
Sony BDUX10S Blu-Ray
HT Omega Striker
Western Digital Caviar Green 2TB 20EARS
120 GB OCZ Vertex SSD
Old July 18, 2009, 08:55 PM
Yes i have noticed this difference in performance as well. some of the things i do often like winAVI and winrar that eats up memory is faster on the i7. but other times i have found to be faster on my test phenom2 810 setup.
i've always had nvidia GPUs so i can comment on the 4870s.
Old July 19, 2009, 04:10 AM
gingerbee's Avatar
sorry would have to see this for myself cause i just built an amd system based on the 810 adn my i7 destroys this thing in games so ( i trusted toms and you know what it got me wrong info that's right they lied ) tomshardware RIP it died when they got bought out ha ha HWC and anandtech are the only sites i tend to trust these days.
Overclocking HELP please Crysisfan11 Overclocking, Tweaking and Benchmarking 1 May 27, 2009 10:15 AM
Needs some help overclocking lanken123 Overclocking, Tweaking and Benchmarking 0 April 21, 2009 11:51 AM
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 28, 2008 12:05 AM
Overclocking P4 1.8 Kassela Overclocking, Tweaking and Benchmarking 1 December 27, 2007 12:28 PM
Need help overclocking further Kessler Overclocking, Tweaking and Benchmarking 15 December 5, 2007 06:09 PM
