View Poll Results: What are your core temps during Linpack testing?
More than 90C (scary high) 1 8.33%
80-90C 0 0%
70-79C 4 33.33%
60-69C 3 25.00%
50-59C 4 33.33%
40-49C 0 0%
Less than 39C 0 0%
Multiple Choice Poll. Voters: 12. You may not vote on this poll
Old July 5, 2009, 04:22 PM
Default Post your Linpack max temps
I'm curious what sort of temps people are seeing during Linpack stability testing.
Could you post you max temp in the following format:
  • Temp
  • Processor
  • OC freq
  • voltage
  • Whether Load line calibration was used for voltage
  • case, if relevant
  • cpu cooler
You can download OCCT here, use the Linpack test and crank your fans.
Link to developers site: Download - OCCT Website english
Link to Console version of a Linpack tool, this one seems to produce a little higher temps, and does not have a shutdown at 80C:
IntelBurnTest v2.3 download from Guru3D.com
Real Temp is useful for giving as accurate temps as possible:
Real Temp - CPU temperature monitoring
(45nm processors do not provide accurate temp feedback at idle, as the sensors are only tuned to be accurate at TJmax)
Rig: HAF922, Q9450, GA-EP45-UD3P, Corsair H50, 2x2GB Patriot Viper DDR2 800, HIS 5850
OC: 24/7 3.7Ghz @ 1.3v CPU-Z
Old July 5, 2009, 04:28 PM
-75C
-Q9450
-3.8Ghz
-1.34volts (CPU-Z), 1.375 Bios
-Vendetta 2 with Thermalright backplate mount
-Antec 902 case with fans on high (during Linpack)
-LLC enabled
Old July 5, 2009, 08:53 PM
Laptop (What I am using now)
-80C+ (Failed, got too hot)
-T6600
-2.2 Ghz
-1.2Vcore
-Stock Laptop cooling
-Standard Laptop Chassis
Laptop is a Dell Studio 17
Desktop (Currently being rebuilt)
-60C
-E5300
-4.1 Ghz
-1.7VCore
-CoolIT Boreas
-HAF 932
This rig is currently in pieces waiting for its case to be finished though.
Q9550 @ 4.05Ghz (For now...)
8 GB G.Skill Ripjaw DDR3-2000,
2x XFX 4890 XT 1 GB
Asus Rampage Extreme
4x WD 1 TB Blacks in 2 RAID 0 Arrays
HAF-EXTREME
Boreas in loop of CPU, and NB
GPU's on straight water
http://service.futuremark.com/compare?3dm06=11518899
Still a work in progress......
Old July 6, 2009, 05:05 AM
Jackquelegs's Avatar
  • 68C
  • Q9450
  • 3.6
  • 1.34v
  • yes
  • HAF 932
  • See signature
Iapetos
Zephyranthes
Old July 6, 2009, 07:27 AM
If you use this there is no high temp limit other than your cpu throttle:
Old July 6, 2009, 09:29 AM
Cambridge,ON
Asus P8P67 Vanilla
2500k@4700 (4.7Ghz)
Ripjaws 1866
Hyper 212+ & 2 Excalibur fans
EVGA GTX460 Superclocked
Part# 1G-P3-1372-TR
Antec P280-all tricools low spd & 2 on front.
Seasonic S-12 650 Energy +
Old July 6, 2009, 09:30 AM
Settings for pevious screen shot.
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ............... Auto
CPU Clock Ratio ..........................10x
Fine CPU Clock Ratio.....................0
CPU Frequency ...........................3.60(360x10)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................Enabled
CPU Host Frequency (Mhz) ............360
PCI Express Frequency (Mhz) .....100 lock
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................800 default
PCI Express Clock Drive................900 default
CPU Clock Skew (ps)....................0
MCH Clock Skew (ps)...................0
DRAM Performance Control
Performance Enhance................Extreme
Extreme Memory Profile (X.M.P.).....Profile 1
(G)MCH Frequency Latch............... 333
System Memory Multiplier ..............2.40b
Memory Frequency (Mhz) ..............800 864mhz. actual
DRAM Timing Selectable ................Manual
Standard Timing Control
CAS Latency Time................5
tRCD .................................4
tRP'....................................4
tRAS..................................12
Advanced Timing Control
tRRD..........................................3
tWTR..........................................3
tWR............................................6
tRFC...........................................52
tRTP...........................................3
Command Rate (CMD) .................2 T
Driving Strength Profiles
Driving Strength ............................1066
Channel A
Static tRead Value..........................7
tRD Phase0 Adjustment...................auto
tRD Phase1 Adjustment...................auto
tRD Phase2 Adjustment ..................auto
tRD Phase3 Adjustment...................auto
Trd2rd(Different Rank)....................auto
Twr2wr(Different Rank)...................auto
Twr2rd(Different Rank)...................auto
Trd2wr(Same/Diff Rank)..................auto
Dimm1 Clock Skew Control...............auto
Dimm2 Clock Skew Control...............auto
Channel B
Static tRead Value.........................7
Twr2rd(Different Rank)....................auto
Motherboard Voltage Control
Voltage Type.………... Manual
CPU
Load Line Enabled
CPU Vcore….……….....1.3750v
(cpu vid range 0.850v-1.36250v)
CPU Termination….....1.320v
CPU PLL…………………...1.500V
CPU Reference.…………0.836v
MCH/ICH
MCH Core…………….....1.240V
MCH Reference….…….0.756v
MCH/DRAM Ref.….....1.000v
ICH I/O………………......1.500V
ICH Core…………...….…1.200v
DRAM
DRAM Voltage ……....2.000v
DRAM Termination…..1.000v
Channel A Reference 1.000v
Channel B Reference 1.000v
Advanced Settings
Limit CPUID Max. to 3....................Disabled
No-Execute Memory Protect.............Enabled
CPU Enhanced Halt (C1E)................Enabled cpu throttles according to load on it.
C2/C2E State Support.....................Disabled
x C4/C4E State Support..................Disabled
CPU Thermal Monitor 2(TM2) ..........Enabled
CPU EIST Function..........................Disabled
Virtualization Technology.................Disabled Enabled if you use VMware/Virtual PC
Integrated Peripherals
Legacy USB Storage Detect .............Enabled
Other settings
Lan 1 enabled
Lan2 disabled
green Lan disabled
on board serial port 1 disabled
on board parallel port 1 disabled
On board sata/ide device disabled
onboard 1394 enabled
sata port 0-3 native mode enabled
sata raid ahci disabled
All usb 1.0/2.0 controller enabled
have usb mouse and keyboard all that enabled
floppy drive1.44 enabled…….I use one
floppy 3 mode support disabled
delay for hdd 0
Temps shown on OCCT while running at its maximum test phases observed are 62-64
Keep in mind thats under its full LinPak load possible test condition
per screen shot Custom Test Mode Max (90% free memory) Test Duration Time 4hr 0min.
And a 3hr test also displayed same parameters.
Cambridge,ON
Asus P8P67 Vanilla
2500k@4700 (4.7Ghz)
Ripjaws 1866
Part# 1G-P3-1372-TR
Old July 19, 2009, 03:42 PM
Cambridge,ON
Asus P8P67 Vanilla
2500k@4700 (4.7Ghz)
Ripjaws 1866
Part# 1G-P3-1372-TR
Old July 19, 2009, 05:02 PM
1Tanker's Avatar
-52C/10 passes IBT
-GA P35-DS3L
-Q9550-C1@3485(410x8.5)
-TRUE..2xScythe SS 1200rpm(68cfm/each) push/pull
-1.20 vCore
-CM RC690
-2x2GB Mushkin XP - PC2 8500(996599) -1025@5-5-5-12 2t @ 2.06v
-BFG 9800GTX+ OC@ stock(760/1885/2250) w/stock cooling
-Corsair VX550
Old September 10, 2009, 12:03 PM
Putz's Avatar
Have my 920 d0 @ 1.2v for 3.87 ghz and it is usually 59-62 between the cores on LinX
Samsung 305t+ 30"
i7 920 @ 3.875 1.20v /EVGA Classified/12gb gskill1600/Two EVGA gtx285 SC 2gb SLI
2xIntel x-25-m SSD Raid 0 / Antec 1200 / Corsair 1000w / Win7 RTM /Auzentech Forte
QNAP TS-209II 2x1TB Raid 1 NAS
heat: http://heatware.com/eval.php?id=244
Tags
linpack , overclock , stability , temps , testing
Post your IDLE temps! BrianHanna Cases 28 February 23, 2009 10:58 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 01:34 PM
TJ. Max Computergeek CPU's and Motherboards 11 March 30, 2008 12:37 AM
Max temperature Vinnie Overclocking, Tweaking and Benchmarking 4 November 28, 2007 09:08 PM
