Old July 6, 2009, 10:23 AM
Cowboy's Avatar
ok, after this run I'll set my timings to 4-4-4-12-22-2t
oc'ed gpu to 955/1125 nets me 17.97k ~ 18k
GPU: max=35C, min=31C
CPU: max=43C, min=28C
Originally Posted by Supergrover View Post
What is your NB running @? I found the NB needed a little goose in volts to even get passed 3.75. For me that was +100mv.
NB is @ stock V core. I will increase it aswell.
Old July 6, 2009, 10:34 AM
Supergrover's Avatar
R.I.P.
Old July 6, 2009, 10:50 AM
Cowboy's Avatar
set timings to 4-4-4-12-22-2t and get 18060 in 06.
Also upped the NB voltage, just a tad tho.
EDIT/Update:
Pushed the NB to 204 (205 would crash in '06) and got a score of 18.3k in 06'
ram @ 816 4-4-4-12-22-2t
cpu@ 3.876 ghz
Thanks guys, I got a stable score at just below 3.9 ghz. not bad.
I'm still open to suggestions on how to make it better. (I.e should i drop the multi a bit and up the NB for better ram performance at the same cpu freq?)
Old July 7, 2009, 03:23 PM
If the new Phenoms are anything like the old Athlons, tighter timings usually gives you the better performance compared to higher clock
Old July 7, 2009, 03:43 PM
Cowboy's Avatar
good to know,
I've got my ram currently at ddr2-816 and 4-4-4-12-22-2t timings @ 1.88v
Any room for improvement?
Overclocking HELP please Crysisfan11 Overclocking, Tweaking and Benchmarking 1 May 27, 2009 10:15 AM
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 28, 2008 12:05 AM
Overclocking P4 1.8 Kassela Overclocking, Tweaking and Benchmarking 1 December 27, 2007 12:28 PM
Need help overclocking further Kessler Overclocking, Tweaking and Benchmarking 15 December 5, 2007 06:09 PM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
