Old June 27, 2009, 09:13 PM
Default Novice overclocker could use some guidance!
Hey folks, I've started to get into the overclocking fun, but could use a little hand holding. :)
My components:
AMD PH2 720BE
Xig HDT HSF
Asus M4A78-E Mobo
Corsair DDR2 800 CL 5-5-5-18 Ram
I'm currently just fooling around using AMD's overdrive utility and have reached 3.6 just using the multiplier (x18), but this required a slight voltage boost to 1.425 (the top end of the rated spec I believe). Temps are 33-34ish under load. I could reach 3.5 with no voltage boost. No luck reaching 3.7 with just the multiplier..
So what's the next step? Do I move up the HTT clock? Is this where I start going to RAM (I find the whole RAM/FSB multiplier rather confusing despite all the guides :(). I would like to reach 3.7-3.8..preferably without having to push the voltage any higher.
Old June 27, 2009, 10:08 PM
stoanee's Avatar
Google is your friend..
bit-tech.net | Guide - Overclocking AMD's Phenom II X3 720 BE
heatware
How does this new build look (Novice) OBNO New Builds 40 June 4, 2009 07:06 PM
need some guidance.. omgwtf Networking 1 January 31, 2009 04:28 PM
A little guidance cerialkillar New Builds 14 January 24, 2009 04:31 AM
The Overclocker, Issue #3 is out!! Bojamijams Overclocking, Tweaking and Benchmarking 3 December 29, 2008 12:34 AM
i7 not much of an overclocker? Babrbarossa CPU's and Motherboards 9 October 14, 2008 06:01 AM
