Old June 25, 2009, 07:35 PM
Magnetar's Avatar
Default OC: P5Q Pro, Q9650, 8GB Ascents
Working on a simple OC for my system. Nothing to extreme or OCD.
Right now I'm testing it with the following settings:
423 Mhz Bus Speed (1692.2 Rated FSB) x9 Multi = 3807.4Mhz.
I have my vcore set to 1.2750, and it reads as 1.264 in CPU Z.
The RAM is at a 1:1 ratio, auto timings (5.5.5.18) at 2.1 volts.
Seems to be quite happy right now. We'll see if it stays that way though...
I played around for a while trying to keep it at 4Ghz but I wasn't comfortable with the temps.
Right now (at 3.8Ghz) the first core hits 61, and the rest hit 57 and 56.
It's running 2x Orthos small FFTs, affinity set for 2 cores per.
I always keep it below 60, but I'm considering letting it slide with 61 if it proves to be stable in the end.
Good idea? Please let me know what you think.
Sorry if I'm rambling, I'll blame it on a major lack of sleep..
Old June 25, 2009, 07:37 PM
geokilla's Avatar
Are you using Core Temp? My safe temperature is 65C. Besides, how often do your programs are as intensive as Orthos, OCCT, etc. Folding@Home could be one of them but besides that, not many.
Try using OCCT instead of Orthos. It's much better. Also are you stable with just 1.275Vcore? That's really low.
Old June 25, 2009, 07:45 PM
Magnetar's Avatar
I'm using Real Temp 3.00.
True that, Gaming is the hardest I'll push this thing.
I'll use OCCT too. I was planning to after a run of Orthos.
Honestly, I'm not to sure which is the best way to test for system stability anymore. I just do the old time consuming, Orthos for 12 hours, Prime95 for 24 hours, and a run of OCCT for good measure.
If you know of a less time consuming way, please do enlighten me.
Yeah, I had my fingers crossed for this vcore!
I did have it running at 4.0 for a while (too hot) at that, but that was the lowest I could take it for 4.0.
After that I figured 1.275 was a safe bet for a low vcore at 3.8. Thus far it's paying off.
ps. When I touch my NB, its feels pretty hot.
Anyone know safe temps for it. Should I worry about it being on auto right now given the setting I listed I'm on??
Old June 26, 2009, 05:36 AM
The Linkpack based tests seem to be the most stressful.
Use the OCCT Linkpack, or Intel Burn Test. If it is going to fail, these tests can flush it out within 15minutes, whereas Orthos may need to run for 8hrs before failure.
Be prepared for an extra 8-10 degrees with Linpack above Prime95 or Orthos.
Old June 26, 2009, 06:10 AM
bojangles's Avatar
What's another degree? to me 60 = 61. There's nothing wrong with that. I say go to 65 and call it quits if you want to stay safe.
Old June 26, 2009, 05:49 PM
Magnetar's Avatar
I passed OCCT Linpack. Temps got to 66 which is okay for Linpack IMO.
All other tests passed too.
Thank you all for you feedback!
Final data for those who may be on a similar journey someday:
3.8Ghz = 3807.4 Mhz
Bus Speed = 423
FSB Rated = 1692.2
Vcore = 1.2750 (CPUZ = 1.264)
CPU Ratio = Auto
FSB Frequency = 423
PCIE Frequency= 101
CPU Voltage = 1.27500
CPU PLL = 1.54
FSB Termination Voltage = 1.28
DRAM Voltage = 2.10
NB Voltage = 1.26
LLC = Auto
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
CPU Clockscrew = Auto
NB Clockscrew = Auto
CPU Margin Enhancement = Optimized
[WTB] P5Q pro and 8400 e0 Phillie Buy/Sell & Trade 1 March 29, 2009 08:24 PM
Linux on P5Q-Pro anyone? The MAX O/S's, Drivers & General Software 2 February 13, 2009 10:28 AM
Anyone running 8GB of Ram in the P5Q-Pro? Issues? The MAX RAM 7 February 10, 2009 08:19 PM
P5Q-PRO Build element291 New Builds 7 January 20, 2009 02:51 PM
p5q pro n0rd1c CPU's and Motherboards 1 November 22, 2008 12:49 PM
