Old June 25, 2009, 10:49 AM
Rocco_360's Avatar
Default So The i7 Overclocking Begins...
Hey guys hows it goin. I got all my computer together and I believe that I'm ready to begin overclocking. I recently installed my Thermalright TRUE 1366 and IC Diamond7 Carat thermal paste. On full load with Prime 95 for an hour my CPU ran from 55-58c. Unfortunatly I do operate in a very warm room which likes to go from 26-29c which sucks. I am new to overclocking so I am still learning along the way. I am hoping to get to at least 3.5ghz. I will be updating this thread along the way. I am using EVGA E-Leet to overclock, Prime95 to test and RealTemp to monitor temperatures.
Cooler Master HAF 932 || EVGA X58 3x SLi || Intel Core i7 920@ 3.7GHz || Corsair Dominator 6GB DDR3 1866MHz || EVGA GeForce GTX 275 FTW || Corsair TX850w || Auzentech X-FI Forte 7.1 || Western Digital Caviar Black 1TB || Seagate Barracuda 500gb || Corsair H50 CPU Cooler ||
Old June 25, 2009, 03:47 PM
Rocco_360's Avatar
First Overclocking:
2.997.1~58-61c (stock voltages)
3198.7~60-65c (stock voltages)
3319.7~60-66c (stock voltages)
3412~crash(stock voltages)
I'm going to input this into the BIOS then begin again.
Old June 25, 2009, 03:50 PM
Rocco_360's Avatar
Second Overclock:
3427.2~63-67c Idle=44c(stock voltage) In vista this is considered 3.25ghz
3507.8~Blue screen error 124(Increase CPU VTT voltage) (stock voltage)
3507.8~62-67c(VCORE at stock, CPU VTT =1.12500)
3642.2~65-71c(CPU VTT=1.27500, VCORE=0.01875 added to stock V, DIMM=1.65000
Old June 25, 2009, 10:33 PM
rjbarker's Avatar
If you Post an actual Template them it gives us something to look at and analyze / assist with......Sorry, your numbers don't really mean diddly...
(old RIVE n 3930K)
Firestrike Extreme: 21.452
MARK 11: 32.530
Old June 25, 2009, 10:48 PM
3oh6's Avatar
Hardware Canucks Reviewer
why does he have to be asking for help? and why the need for the entire BIOS template? he is posting the relevant voltages and his clocks. his numbers mean what they should mean, to me at least, thanks for posting and keep the clocks going...looking good so far
Old June 26, 2009, 09:00 AM
rjbarker's Avatar
3oh.....a tad more clarity is what I like to look at ....are those all idle or load temps?? What is "Stock"...from what I've seen VID is different for many Chips....
btw.....did you get your mitts on that Waterblock for your Classified Northbridge?...if so how did you find your Temps afterwards? I've been away for the month at work but prior to leaving I was playing around with both 40mm and 60mm fans on my Northbridge with not a whole lot of success in pulling down the Temps..
(old RIVE n 3930K)
MARK 11: 32.530
Old June 26, 2009, 09:07 AM
gingerbee's Avatar
that's a good question cause i did not think there was an app that told core vid for the core i7 yet ( and this seems to be a looked at my overclock thread not help me overclock thread just a thought)
Old June 26, 2009, 09:09 AM
gingerbee's Avatar
the numbers make perfect sense to me and if you read the first thread temps are under load using prime 95 ( btw does the evga NB run that hot guys )
Old June 26, 2009, 09:34 AM
rjbarker's Avatar
Evga X58 utilize a Fan for cooling NB...Classified NB is "passive"...
At present from Cold Boot to BIOS NB Temp is around 58c
After intense gaming...restart to BIOS NB Temp around 67c
Not sure what it is hitting while actually gaming....(not sure if I really want to know )
(old RIVE n 3930K)
MARK 11: 32.530
Old June 26, 2009, 09:55 AM
gingerbee's Avatar
wow omg great board but temps ah thank for the info Rj.
Phase 1, Project 2 Begins... death_hawk Case Mods, Worklog & Gallery 40 September 16, 2009 02:33 PM
Final Build, Paid For, Now The Waiting Begins...! mlauzon New Builds 20 December 27, 2008 12:42 AM
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 28, 2008 12:05 AM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
The Office Arms Race begins Again SKYMTL Off Topic 2 April 19, 2007 11:28 AM
