<~----> Overclocking an E7400 - Hardware Canucks
Old June 21, 2009, 09:08 PM
Sheep's Avatar
Default Overclocking an E7400
Hi,
I'm a huge newb when it comes to overclocking, and most of the guides I've tried to read are way over my head. I know that FSB plus multiplier are what equals your speed, and the higher the FSB, the faster the system is on a whole. Here's my system:
Asus P5Q pro
E7400
G.Skill PC2-6400
Thermalright AXP-140
HD4870
Currently, I'm at a FSB of 333 with a multiplier of 10. The CPU voltage reading from CPU-Z is 1.3v. Should this be lower? With this FSB setup, should I be worried about my PCIE Bus? These are my only 2 real concerns.
Thanks,
Brian
Old June 22, 2009, 05:38 PM
Sheep's Avatar
Ok no cream.
Sheep
Old June 22, 2009, 05:40 PM
gingerbee's Avatar
trial and error try and lower the voltage until it will not boot or is unstable ( as long as the pcie is set to 100 mhz then your fine)on a p5q i got my e7200 to 3.8@ 1.36v
Old June 22, 2009, 06:20 PM
Sheep's Avatar
Thanks fr the reply. With the current voltage my temps are still fine. I think I'll just leave that alone.
Thanks for clearing up the PCiE slot bus.
Sheep
Old June 22, 2009, 06:56 PM
gingerbee's Avatar
no problem at all those chips run very cool
Old June 22, 2009, 07:01 PM
Realityshift's Avatar
The E7400 runs a multi of 10.5 does it not? Why not set it to 10.5 and a FSB of 343 - 345 to get 3.6ghz, My E7400 ran these settings with great temps at 1.326v. Your motherboard should be auto configing your CPU to run a 10.5 multi since its the CPUs default.
The Builders Hammer
Old June 23, 2009, 12:44 PM
Sheep's Avatar
I lowered down the Multi just to be safe. I wasn't sure how well the AXP140 would cool the CPU. I'll change the Multi back to 10.5, and see how that goes. 333fsb is fine for me.
Thanks for the reply,
Sheep
Old June 23, 2009, 05:36 PM
Sheep's Avatar
Changed the Multi back to 10.5 and running 3.5GHz.
Superpi 1m at 15 seconds, 2m at 40s flat.
Sheep
Old June 23, 2009, 06:07 PM
gingerbee's Avatar
raise the fsb till she won't boot then back off by 10 mhz and start to run some prime or occt stress tests to check if it's stable. and i always leave my TM function on
Old June 23, 2009, 07:36 PM
Sheep's Avatar
I think I'm good where I'm at. I don't think eeking out another 100MHz is going to make a huge every day difference.
Thanks for the help though,
Sheep
[FS] E7400 $130 shipped Realityshift Buy/Sell & Trade 6 April 24, 2009 12:18 AM
E7400 SLI overclocking build.. Realityshift Case Mods, Worklog & Gallery 1 March 9, 2009 02:54 PM
[WTB] Intel CPU E7400 tyreman Buy/Sell & Trade 7 February 22, 2009 02:47 PM
E7400 Machine xsever New Builds 5 January 21, 2009 02:14 PM
