Old June 20, 2009, 11:15 AM
Default New Build with E5200 overclocked
Just built this baby and overclocked it yesterday. Ran Prime95 for 8 hours so I think it's stable.
Idle temps are 31-33 and at 100%, it got up to 57 degrees.
My CPU Core voltage in my BIOS is 1.3V but CPU-Z shows 0.98V, which one is right?
My first overclock so any suggestions would be great!
Old June 20, 2009, 11:27 AM
CMetaphor's Avatar
Quadfather
You're probably seeing the voltage when EIST is on (speedstep). Pretty good temps though, what are your running @ ?
Old June 20, 2009, 11:34 AM
What do you mean?
CMetaphor's Avatar
Quadfather
The frequency of your Overclock? FSB? Ram timings? Just post a screenshot of your CPU-z if youre not sure...
Old June 20, 2009, 11:48 AM
I did post a screen shot of my CPU-Z. Is it not working? lol
Frequency - 3.6 GHz
FSB = 1200 mHz
Ram Timings = 5,4,4,12
Old June 20, 2009, 12:00 PM
CMetaphor's Avatar
Quadfather
That's not bad for 1.3v. Good temps too. What cooler are you using?
Old June 20, 2009, 01:46 PM
I got the Arctic Cooler Freezing 7. It's working pretty good
Old June 23, 2009, 03:05 PM
There's a small problem with my overclock now. I added a 4830 to my system and my overclock became unstable. Does anyone know how to correct this? Increasing the cpu voltage won't help, right? How about the NB voltage?
Any help would be appreciated!
Old June 23, 2009, 04:00 PM
punk_zappa's Avatar
Please post other parts that's in this rig.
Old June 23, 2009, 05:36 PM
EVGA nForce 730i motherboard
2x2 GB OCZ Reaper pc8500 Ram
4830 Sapphire 512mb Video Card
Seagate SATA II 250GB Hard drive
600W Enermax Noisetaker PSU
Windows 7 RC OS
Intel E5200 low Budget Gaming Build DarXViruS New Builds 14 June 27, 2009 12:00 PM
Yet Another E5200 OC. Digital_fx3 Overclocking, Tweaking and Benchmarking 4 February 17, 2009 02:33 PM
e5200 OC SUCCESS!! Bucklaz Overclocking, Tweaking and Benchmarking 29 February 16, 2009 09:57 AM
E5200 Able to Keep Up? Trevor CPU's and Motherboards 5 February 14, 2009 10:03 AM
