Old June 23, 2009, 05:50 PM
When I first installed the video card, it messed up my overclock and I had to re-do it.
I took out the video card and re-set the overclock settings. I got it stable at:
FSB (qdr) = 1120mHz
Mem (ddr) = 560mHz
Multiplier = 12.5
CPU Freq = 3.50gHz
Memory Timings = 5,4,4,11
CPU Core = 1.35V
CPU FSB = 1.4V
Chipset Voltage = 1.1V
Memory = 1.9V
CPU PLL = 1.5V
Old June 25, 2009, 08:20 AM
Well, the stupid motherboard was the problem. It was overheating with the video card installed. So went out and got a EP45-UD3R. Great board! Got even a better overclock with this motherboard.
3.75gHz (300 x 12.5) at only 1.31 Volts
Ran prime95 for 10 hours and no errors.
Might try for 4.0 gHz in a little bit.
Old June 25, 2009, 11:02 AM
CroSsFiRe2009's Avatar
nice oc, oh, btw was there an option to lock the pcie to 100 on your old mobo? might explain why the video card caused it to become unstable
Old June 25, 2009, 05:47 PM
There was an option for pcie but the only two toggles were enabled and disabled. It didn't allow you to input a value for it.
Old June 26, 2009, 04:43 AM
curtispan's Avatar
Wow that is a very nice overclock. I'm struggling to hit 3.0Ghz with a mobo that's somewhat similar to yours.
Intel E5200 low Budget Gaming Build DarXViruS New Builds 14 June 27, 2009 12:00 PM
Yet Another E5200 OC. Digital_fx3 Overclocking, Tweaking and Benchmarking 4 February 17, 2009 03:33 PM
e5200 OC SUCCESS!! Bucklaz Overclocking, Tweaking and Benchmarking 29 February 16, 2009 10:57 AM
E5200 Able to Keep Up? Trevor CPU's and Motherboards 5 February 14, 2009 11:03 AM
