Well Mibs.....I thought I had a handle on overclocking an intel but after reading your post I'm also CONFUSED now...Thanks...lol. Not sure about this answer but someone should be able to help shortly
__________________ Amd FX60 @2.9 Asus A8R32-MVP Deluxe 2 Gig Corsair XMS 4000PT 2 Ati X1900's @XTX Speeds 2 WD 160gg HD's in Raid 0 XFi Platinum Tt 680 Watt PSU SATA Plextor DVD (Liquid Cooled) Swiftech Apex Ultra and 2 MCW 60's Kandalf |
| Quote:
It can get confusing because of the different FSBs that current intel chips run at, but to the user it's mainly hidden by use of memory dividers behind the scenes. An example would be using DDR2 800 with a 1066 (4 X 266) proc....... With the 266 chips, selecting a "memory speed (or type)" of DDR 533 (2 X 266) will automatically set a memory divider of 1:1 and memory will scale directly with changes to FSB. If we want to use DDR2 800 with a 1066 (4 X 266) CPU, we set it for DDR 800 in Bios and the bios automatically sets a mem divider of (don't quote me on this... :) ) 2:3 with FSB being the two and mem speed being the three this gives us a memory speed of DDR 400 with a stock FSB of 266. With this setting, mem speed will scale faster than cpu speed as we raise FSB. All that happens when we bring in a 1333 (4 X 333) FSB chip is that the mem dividers are changed to bring memory in line with the higher FSB. With a 333 chip, your 1:1 ratio would be DDR2 667 (2 X 333) and your ratios for the other mem speeds will change to bring them in line at stock FSB. Clear as mud???????
__________________ Gigabyte P35-DQ6 / E8400 / 2X2 Gig Mushkin PC2 8500 Ascents / Corsair TX750W PSU / Gigabyte 8800GTS / CoolerMaster Cosmos S / MCP655 WC Pump / MCR320 Rad / 6X Yate Loons / PA120.1 / 2X Scythe Ultra Kaze / Swiftech Apogee GTZ WB / Samsung 2253BW ASUS P5Q Pro / Q6600 / 2X1 Gig Supertalent PC2 6400 / PC P&C 750W Silencer / HIS 3870 IceQ3 / HT Omega Striker 7.1 / MCR220-QP-Res / DD DDCPX-Pro / Apogee GT / Swiftech MCW30 / Highspeed PC Tech Station / Samsung 931BF |
| Heh, it's hard to explain clearly other than to say that the bios automatically sets a divider based on what the stock FSB of your CPU is X what a person selects as installed memory speeds and thus arrives at the proper stock memory speeds. Just to further muddy the waters.... most high end 1066 DDR2 is in fact just well binned DDR 667 or DDR 800 so the auto SPD settings don't pick it up for what it's supposed to run at. OC'ing memory on the A64s was sooooooo much easier!!!!! :)
I didn't mean when replying that your own reply was thick as mud... I meant that the whole process of oc'ing Mem can be "difficult" at times and is very difficult to explain clearly. I've been oc'ing for 5 years, I would have a very hard time explaining Mem speeds to someone new in clear, concise terms. I think you did your best, and re-reading your reply it does make sense. John |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Anybody heard or used PNY Memory? | chibi_man | RAM | 2 | December 4, 2007 11:42 AM |
| memory question please?!?!?! | bushwickbill | RAM | 3 | September 26, 2007 08:26 PM |
| Memory problems!!!! | free2fly | Troubleshooting | 5 | August 25, 2007 12:57 AM |
| Which Memory? | BALISTX | RAM | 11 | April 3, 2007 11:52 PM |
| ...is it a memory problem? | francois methot | Overclocking, Tweaking and Benchmarking | 9 | March 24, 2007 12:33 AM |
