Old June 15, 2009, 09:07 PM
somecanadianguy's Avatar
Default Overclocking a GTX275...
I've started messing around with my GTX275.
Came factory OC'd to 648/1458/1188.
First I upped it to FTW speeds... 713/1512/1260.
Tested with Furmark and all seemed good.
After a bit more messing around, I have it up to 735/1593/1277.
For some reason I can't type in shader speed like I can with the others.
Where should I go from here?
I'm learning, and my card looks like a decent OC'er, but I'm not sure if I'm doing it right.
What problems should I be looking out for?
How far should I try to push it?
Is Furmark really a good test, or should I try something else?
I planned to run Vantage after I get my highest stable clocks in Furmark.
10 mins of Furmark and temps are around 80c with fan @ 100%.
**edit**
I'm using EVGA Precision to OC
Old June 15, 2009, 09:22 PM
SugarJ's Avatar
If you are using EVGA's Precision software, there is an option to unlink the core and shader frequencies.
Old June 15, 2009, 09:24 PM
Yeah, it's EVGA Precision... core and shader are unlinked.
I still can't type in the shader speed.
**edit**
closed/re-opened precision and it works fine now .
Old June 15, 2009, 09:27 PM
Are you sure its unlinked, i used evga percision a bit to get my settings to 733/1600/1232 but i put it back to defualt, i didnt see the need to overcloack, its not like any games currently push the gtx 275 when its running stock speeds.
Old June 15, 2009, 09:30 PM
I doubt I'll run it like that 24/7, but its fun to play around.
Some of the graphics programs I use may run better with it OC'd.
Once I get it folding I'll probably want to run OC'd for that too.
Mostly, I'm just doing it for the hell of it.
It's 12:30am... I'm full of coffee and bored out of my mind...
Why not have a little fun?
Old June 15, 2009, 09:42 PM
Prof. Dr. Silver's Avatar
This is where you run 3DMark06 and Vantage, OC your CPU and RAM as well to get the highest score possible and then you sign up for HWBot!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old June 15, 2009, 09:45 PM
Don't know if I can get a score worth uploading... I'll try though.
Can get my CPU stable enough for Vantage @ 4GHz...
My RAM isn't very good so I'm kinda scared to push it much.
Old June 15, 2009, 09:49 PM
Hey, I personally believe OC'ing is pushing your hardware to its limits! That is all the fun right there! E.g. If it doesn't run at 1500MHz.... set it at 1499MHz and try again...
Show us what you got!
GTX275 Vantage score low? somecanadianguy Overclocking, Tweaking and Benchmarking 8 June 3, 2009 06:11 AM
EVGA GTX275 questions... somecanadianguy Video Cards 15 May 30, 2009 06:15 PM
GTX275 Installation? somecanadianguy Video Cards 4 May 29, 2009 12:13 AM
So, I'm thinking of selling my GTX275 Sagath Off Topic 5 April 30, 2009 11:32 AM
Need help overclocking further Kessler Overclocking, Tweaking and Benchmarking 15 December 5, 2007 06:09 PM
