Old June 8, 2009, 03:09 PM
andynerd's Avatar
Default Looking for an i7 blender benchmark
Hey everyone I am looking to see how long it takes to render a 150 frame fluid collision in blender as a quicktime @ 15fps in the h.264 codec on an i7 system. So it looks like the attached video video. If you want the .blend file so you just have to render it then ask. Just wondering because on my old Pentium D 945 it takes a good 30 minuets to render!
"let the geek be with you"
Specs: Asus G74SX
Old June 8, 2009, 03:29 PM
MpG's Avatar
MpG MpG is offline
So is this file some sort of self-contained benchmark, you're saying?
Old June 8, 2009, 03:53 PM
CMetaphor's Avatar
Quadfather
Oooooh, send it to me I'll try it on Behemoth for comparison...
Old June 8, 2009, 03:56 PM
Using blender requires you to download a lot of stuff.. be warned.
Old June 8, 2009, 04:25 PM
MpG's Avatar
MpG MpG is offline
Ah, so "Blender" is an actual program? I've never heard of it, I have no idea.
Old June 8, 2009, 04:53 PM
somecanadianguy's Avatar
blender.org - Blender 2.49
Blender is great
I use it all the time.
You'll also need Python 2.5.2 to get all the scripts to work.
Python 2.5.2 Release
I'm pretty sure Blender will work without Python installed, but you won't be able to use some of the scripts and stuff.
I think you also need a version of Microsoft Visual C++ Redistributable installed, but I forget which one exactly.
Old June 8, 2009, 07:18 PM
andynerd's Avatar
here ya go the project file
Specs: Asus G74SX
Old June 8, 2009, 07:21 PM
andynerd's Avatar
That would be interesting to see how well blender renders physics,images,and animations on your computer! lol!
Specs: Asus G74SX
Old June 8, 2009, 08:04 PM
CMetaphor's Avatar
Quadfather
Im on it... so just to double check:
150 Frames
15 Fps
H.264 Codec
Quicktime (.MOV) format?
Old June 8, 2009, 09:18 PM
CMetaphor's Avatar
Quadfather
Hmmm. considering ive never usd Blender before perhaps you could re-send that project with the camera in the correct orientation (its a B****) and with the proper resolution set (400x300, as opposed to the 800x600 default). Throw me a bone and ill help ya... lol
Memory Benchmark enaberif Overclocking, Tweaking and Benchmarking 2 October 13, 2008 04:00 PM
wPrime Benchmark v1.58 Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 5 February 5, 2008 11:55 AM
New Benchmark! Prof. Dr. Silver Off Topic 11 January 15, 2008 11:51 AM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 08:26 PM
PCMark05 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 8 November 15, 2007 05:57 PM
