  #21 (permalink)
Old June 10, 2009, 03:36 AM
andynerd's Avatar
800 by 600 in quicktime formate @ 15 frames a second on the h.264 codec it is on the first post
"let the geek be with you"
Specs: Asus G74SX
  #22 (permalink)
Old June 10, 2009, 09:04 AM
somecanadianguy's Avatar
Originally Posted by andynerd View Post
Hey everyone I am looking to see how long it takes to render a 150 frame fluid collision in blender as a quicktime @ 15fps in the h.264 codec on an i7 system. So it looks like the attached video video. If you want the .blend file so you just have to render it then ask. Just wondering because on my old Pentium D 945 it takes a good 30 minuets to render!
It is...?
I'll give it a shot right now @ stock, and again OC'd.
  #23 (permalink)
Old June 10, 2009, 09:51 AM
CMetaphor's Avatar
Quadfather
FOUND THE PROBLEM! It was because my file was made in 32-bit and you guys used 64-bit, here is the one I made in 64-bit ubuntu!
I'll try it late tonight once im home.
  #24 (permalink)
Old June 10, 2009, 02:45 PM
andynerd's Avatar
Ok never mind still getting the problem -_-
Specs: Asus G74SX
  #25 (permalink)
Old June 10, 2009, 02:55 PM
The last one you posted worked fine for me.
I'm using Blender 2.49 32bit.
Too bad 64bit Blender doesn't support Quicktime yet.
800 by 600
quicktime format
h.264 codec
15 frames per second
150 frames
It took just over 30mins @ stock settings.
Was that what you wanted?
Does your Pentium really render all 150 frames in 30mins?
**edit**
Tried again @ 3.4GHz and it took around 24 minutes.
These times are without any Vista tweaking.
  #26 (permalink)
Old June 10, 2009, 08:28 PM
CMetaphor's Avatar
Quadfather
I still can't find the quicktime options, or the h.264 options either. But I opened your .blend file and did ctrl-F12 like you said, lol. Its in progress now, looks like itll take 17 minutes when limiting it to 8 cores. Ill try with all 16 enabled for the processor affinity then try that as well. I'll post the times when its done.
  #27 (permalink)
Old June 10, 2009, 08:44 PM
What version of Blender are you using?
64bit Blender can't use Quicktime yet.
If you're using 32bit but just don't know where the option is, check my post with the pic on page 2 of this thread.
You'll see the box on the bottom right of the screen.
And the obvious question... do you have quicktime installed?
If you just opened the file and pressed ctrl+f12 you'll be rendering with the wrong settings.
It's set to use AVI codec or something @ 25fps.
  #28 (permalink)
Old June 10, 2009, 08:52 PM
andynerd's Avatar
sorry I was using 32 bit blender then I just learned now that the new version doesn't have quick time lol woops. And wow 17 minutes that pretty good O_o! I am starting to think is the amount of processing cores (cpu and gpu) that add to the speed of rendering.
Specs: Asus G74SX
  #29 (permalink)
Old June 10, 2009, 08:55 PM
Heh... so what are the exact settings and program versions to use?
I used:
Blender 2.49 32bit
800 by 600
quicktime format
h.264 codec
150 frames
At stock speeds it took around 30mins to render all frames.
andynerd, does your Pentium really render all 150 frames in 30mins?
Something about that doesn't sound quite right.
  #30 (permalink)
Old June 10, 2009, 09:34 PM
I think you might only be running one thread, which would explain why the render times are the same. I'm pretty sure you can set the number of threads in the blender render settings. If not, try a different renderer like Yafray; it'll probably look better too.
Q6600 G0 @ 3.0GHz - P5Q-E - EVGA GTX 260 Core 216 - Corsair TX750 - Coolermaster HAF 932 - Xigmatek HDT-S1283 - Mushkin Redline 2x2gb
Memory Benchmark enaberif Overclocking, Tweaking and Benchmarking 2 October 13, 2008 04:00 PM
wPrime Benchmark v1.58 Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 5 February 5, 2008 12:55 PM
New Benchmark! Prof. Dr. Silver Off Topic 11 January 15, 2008 12:51 PM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 09:26 PM
PCMark05 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 8 November 15, 2007 06:57 PM
