Old June 8, 2009, 09:27 PM
CMetaphor's Avatar
Quadfather
Well.... due to my lack of experience with this program and my utter impatience past midnight, I was only able to render the following: 150 frames, 30fps (oops), 800x600 (forgot to change it back), codec? (cant even find the option for codec, im just using Render Frames). Total time = just under 7 minutes? No idea if i even did it right or not. Like i said, throw me a bone here...
Old June 9, 2009, 04:03 AM
andynerd's Avatar
naa you did it right! For me it takes well over a half an hour to render in that format O_O HOLY C@#$! Wow!
"let the geek be with you"
Specs: Asus G74SX
Old June 9, 2009, 05:14 AM
CMetaphor's Avatar
Quadfather
But I couldn't even find a box to render it into a specific format, Not could I get the same camera angle that you had in your example video.... Not could i find a place to create a video from the rendered frames "buffer" window... sorry, haven't done this stuff in years . Perhaps could you still make a new .blend and explain to me exactly which steps you used? Then I could use exactly the same settings and do a more direct comparison.
Edit: Blender is only threaded up to 8 cores anyway.... I put it on my "Back 8" cores that don't normally work as hard. hehe.
Old June 9, 2009, 02:12 PM
andynerd's Avatar
In this one it is all set up all you have to do is open the program and hit ctrl F12 and it will render the exact same!
Specs: Asus G74SX
Old June 9, 2009, 02:20 PM
somecanadianguy's Avatar
What version of Blender did you do this in?
If I open your file with version 2.49 and press ctrl f12 to render I get this...
All frames look the same.
I'm doing this @ stock speeds for now.
Old June 9, 2009, 02:56 PM
andynerd's Avatar
I am using the same version as you I have no clue why it did that O-o
Specs: Asus G74SX
Old June 9, 2009, 04:50 PM
I tried uninstalling/reinstalling Blender and am getting the same thing.
Old June 9, 2009, 07:47 PM
CMetaphor's Avatar
Quadfather
Dead link on that attachment, it brings me to a blank webpage.
  #19 (permalink)
Old June 9, 2009, 08:34 PM
andynerd's Avatar
FOUND THE PROBLEM! It was because my file was made in 32-bit and you guys used 64-bit, here is the one I made in 64-bit ubuntu!
Specs: Asus G74SX
  #20 (permalink)
Old June 9, 2009, 09:50 PM
Originally Posted by andynerd View Post
Hey everyone I am looking to see how long it takes to render a 150 frame fluid collision in blender as a quicktime @ 15fps in the h.264 codec on an i7 system.
What resolution are you rendering at?
Can you post exact settings to use?
Memory Benchmark enaberif Overclocking, Tweaking and Benchmarking 2 October 13, 2008 04:00 PM
wPrime Benchmark v1.58 Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 5 February 5, 2008 11:55 AM
New Benchmark! Prof. Dr. Silver Off Topic 11 January 15, 2008 11:51 AM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 08:26 PM
PCMark05 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 8 November 15, 2007 05:57 PM
