Old June 7, 2009, 03:10 PM
andynerd's Avatar
Default quick question : Overclocking voids warrenties right?
Just wondering I assume yes but it is always good to ask! ( and i mean overclocking anything like cpu,ram,or gpu)
"let the geek be with you"
Specs: Asus G74SX
Old June 7, 2009, 03:33 PM
MpG's Avatar
MpG MpG is offline
I guess if you want to get technical, it often does.
On the other hand, some components are specifically guaranteed under adverse conditions. An example would be OCZ's EVP on some of their memory, where they'll honour their lifetime warranty for using voltages beyond what the sticks are specced for (to a certain limit, of course). Or motherboard makers that rate their boards for memory speeds beyond the JEDEC specs (i.e. there is no official spec for DDR3-1800 or 2000).
If you're concerned about that sort of thing, you really have to look at things piece-by-piece. To start, I don't believe ANY CPU's are warrantied for overclocking, even the ones with unlocked multipliers. Kind of two-faced, but that's just how things works.
Old June 7, 2009, 03:37 PM
andynerd's Avatar
ok then thanks for the info!
Specs: Asus G74SX
Quick question jspot69 HTPC Systems & Software 4 February 6, 2009 05:39 AM
Quick question Zippoh New Builds 10 December 2, 2008 08:48 PM
Quick Question /b/ derrXIII Video Cards 2 August 12, 2008 02:55 PM
quick question... omgwtf O/S's, Drivers & General Software 14 July 22, 2008 05:31 PM
Quick Question. Khronos Display Units 2 January 7, 2008 01:16 PM
