Old June 1, 2009, 07:49 PM
somecanadianguy's Avatar
Default GTX275 Vantage score low?
I just got a GTX275 (factory OC'd) the other day and decided to download 3dmark Vantage.
I ran it at the default "Performance" setting and got GPU: 8598; CPU: 42551 (stock CPU and GPU speeds)
These look a little low compared to some others I've seen...
http://www.hardwarecanucks.com/forum...-review-9.html
Anyone know what's going on?
Old June 2, 2009, 03:29 PM
Silvgearx's Avatar
wow thats pretty low compared to that chart.
Time to turn up the frequency to 108mhz and try it again
Old June 2, 2009, 04:23 PM
What could the problem be?
Card came factory OC'd to 648/1458/2376.
I'm using the new 185.5 drivers... maybe I'll roll back and try again.
Old June 2, 2009, 05:45 PM
I tried again at 3.8GHz and got around the same GPU score.
Then I remembered that I'd changed some settings in the Nvidia Control Panel .
Reset to defaults and ran 3dMark again...
Overall score: 14342
GPU score: 11560
CPU score: 51559
I was starting to wonder if I got a defective card... guess not.
The card just got a defective user .
Old June 2, 2009, 06:16 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
NEVER mess with the Nvidia control panel before you benchmark. Good catch though.
Cowboy's Avatar
Now THAT... is genuinely funny. I lol'ed IRL.
Old June 3, 2009, 06:05 AM
Old June 3, 2009, 06:06 AM
I'm not used to having a card worth benching with.
Most of the time messing with the control panel is the first thing I do.
Now I have to try and remember what settings I had before so I can work again.
Old June 3, 2009, 06:11 AM
sswilson's Avatar
You're not the only one hit by this problem.... I don't run Vista so no Vantage for me, but I have done this exact same thing with other benchmarks. :)
Even better was the time I moved my 1950pro to the secondary PCIe slot to allow for better cable management.... took me a week to realise that the secondary slot was only running @ 2X speeds and majorly affecting the performance of my card. :)
EVGA GTX275 questions... somecanadianguy Video Cards 15 May 30, 2009 06:15 PM
GTX275 Installation? somecanadianguy Video Cards 4 May 29, 2009 12:13 AM
So, I'm thinking of selling my GTX275 Sagath Off Topic 5 April 30, 2009 11:32 AM
Low score 3dmark06, OC advice? aviduser Overclocking, Tweaking and Benchmarking 15 February 27, 2009 09:44 PM
Strange CPU Score on 3DMark Vantage appplejack Overclocking, Tweaking and Benchmarking 1 January 12, 2009 07:44 AM
