Old July 6, 2007, 04:33 PM
magictorch's Avatar
Default Coolbits
Hi, anyone had any issues with Coolbits? i enabled it in the bios and it seemed to cause some strange startup issues..
Old July 6, 2007, 08:04 PM
magictorch's Avatar
Default ok it works now!!
registry change fine now
Old July 6, 2007, 08:14 PM
Babrbarossa's Avatar
Are you using Vista? scratch that- just saw your second post- (and sig)
Old July 7, 2007, 05:38 AM
magictorch's Avatar
Default coolbits auto adjust
used the autoadjust on coolbits and it raised the clock levels from the BFG OC. however 3dmark06 decreased by nearly 1000points!? not sure about this software. had just installed the microsoft dualcore patch but it was working fine before with AMDS offerings. Ive heard the 7970GT isnt a good overclocker anyway-got it at 47oc idle though. anyone else had trouble with coolbits?
