Old June 5, 2007, 07:34 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Here is my favorite A64 guide, made by George aka eva2000.
AMD64 Overclocking Guide (07/11/06) - i4memory.com
Old June 5, 2007, 07:44 AM
Babrbarossa's Avatar
That is a goody! Thanks- I've updated the list (Pat's version)
I added another 8800 oc guide and an DFI infinity Dark guide for sswilson too
psst, wanna see my binder?
Old June 5, 2007, 11:49 AM
Patriote's Avatar
ATI X1900 and X1800 Series Overclocking Guide
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking
This guide helped me a lot back in the time i had my Saphire X1900XT
Now, with the latest version of ATItool it's a lil useless. But it's still great for noobies!
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old June 5, 2007, 12:08 PM
Thanks! updated.
Old November 30, 2007, 06:29 AM
magictorch's Avatar
Default Asus P35 overclock guide
Found a pretty good guide here for the Asus P35 boards (its an add-on to a more basic guide).
http://forums.hexus.net/hexus-hardwa...s-p5k-add.html
Old September 22, 2008, 08:16 AM
CTA's Avatar
CTA CTA is offline
just curious... can i use Asus P5B-Deluxe: Overclocking and Tweaking Guide - The Tech Repository Forums on my p5q deluxe... i know they are different but same basic idea?
<< non-OC trail is over... so time for OC!
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old January 23, 2009, 12:17 PM
Default Gigabyte GA-EX58-EXTREME with i920 at 4GHz
I found this the other day (I hope to god I didn't find it here, that would be embarrassing).
Over-clock your i7 920 to 4GHz or more on the GA-EX58-EXTREME motherboard
I'm totally new to overclocking, but it was an interesting article. It prompted me to run the SP2004 tests and see what temps my cpu runs at (70c on all 4 cores at 100%, no o/c, stock fan)
I have a i920 but with the GA-EX58-UD5 so don't know if this will even work with my board but might have a play when I get a better cooling.
Apologies if this was already posted
Old January 23, 2009, 02:29 PM
Killswitch's Avatar
What!?!?!?! No Phenom guides!?!?!
Here are a few decent ones that I used.
Phenom Overclocking Guide - Guru3D.com Forums
** Guide to Overclocking Phenoms on AM2+ Boards ** - Guru3D.com Forums
Last edited by Killswitch; January 23, 2009 at 05:23 PM. Reason: Being tired and proper grammar do not mix!
  #19 (permalink)
Old January 23, 2009, 05:07 PM
Thanks Guys- I updated them to Patriote's beautified list
8800GT Bios Flashing Guides MajorBuzzon Video Cards 3 June 1, 2008 10:34 PM
Overclocking guides and tips. belgolas Overclocking, Tweaking and Benchmarking 28 January 24, 2008 03:44 PM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
tech toy guides and faq guides. Il Duce Suggestions & Feedback 0 April 10, 2007 06:08 PM
