Old May 22, 2009, 01:31 PM
Should that not work, seems lke your only choice is to try a different ram divider. You may also want to just try 450 straight-up...bios settings are definately causing your grief.
Old May 22, 2009, 01:41 PM
Yeah why are you running a 5:6 divider? Always try to see where you can go with a 1:1
Old May 22, 2009, 01:55 PM
CanadaRox's Avatar
Tried 450x8 as well as 435 with a 1:1 divider with the same results as before. And I was using a 5:6 divider because then as I maxed out my processor at a around 450-470MHz, my RAM would be just over spec, where as the next step down using 333MHz latch would put it at 900-940MHz which is way under spec. I also know this RAM can do at least 1100MHz at 5-5-5-15 and 2.1V
Here are my exact settings so you can see if there is something I've overlooked (I also did manage to find PL and I now have it set at 8)
Code:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Turbo
CPU Clock Ratio ..........................: 9
Fine CPU Clock Ratio.....................:.0
CPU Frequency ...........................: 3.9
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 435 MHz (or 450/434)
PCI Express Frequency (Mhz) .........:Set to 100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: default
PCI Express Clock Drive.................: default
CPU Clock Skew (ps)....................: default
MCH Clock Skew (ps)...................: default
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: 333
System Memory Multiplier ..............: 2.40B
Memory Frequency (Mhz) ..............: 1044
DRAM Timing Selectable ................: [manual]
Standard Timing Control
CAS Latency Time........................:5
tRCD .........................................:5
tRP'...........................................:5
tRAS..........................................:15
Advanced Timing Control
tRRD...........................................:auto
tWTR..........................................:auto
tWR............................................:9
tRFC...........................................:72
tRTP...........................................:auto
Command Rate (CMD) ....................:auto
Driving Strength Profiles
Driving Strength ............................:
Channel A
Static tRead Value.........................:8
 tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
 tRD Phase2 Adjustment .................:Auto
 tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto  ps
Dimm2 Clock Skew Control...............:Auto  ps
Channel B
Motherboard Voltage Control
Load-Line Calibration.……….............: enabled
CPU
CPU Vcore….………......1.250V*.......: 1.418750
CPU Termination…..... 1.200V*.......: 1.3
CPU PLL…………………....1.500V*.......: 1.5
CPU Reference………....0.760V*.......: [Auto]
MCH/ICH
MCH Core…………….....1.100V...........: 1.38 (tried up to 1.5)
MCH Reference….…….0.760V...........; [Auto]
MCH/DRAM Ref.…......0.900V...........: [Auto]
ICH I/O……………….....1.500V............: [Auto]
ICH Core…………...……1.100V............: [Auto]
DRAM
DRAM Voltage ……....2.060V............: 2.1
DRAM Termination .…0.900V............: [Auto]
Channel A Reference 0.900V............: [Auto]
Channel B Reference 0.900V............: [Auto]
Project: Black and White
Old May 22, 2009, 02:57 PM
isn't there 2.4 A/B/C/D dividers? Did you try the others?
I'm not familiar with gigabyte's bios at all...they were supposed to send me a UD3P board, but didn't, so I haven't had the opportunity to figure it all out.
But you're on a QX, which is gonna be FSB limited in the first place, so really, why don't you just up the multi to 10 and run 400FSB and 1066 ram? the load a QX quad puts on the FSB is HUGE, and while I could run mine @ 470 on P45, I did have an exceptional chip...If i remember correctly, I was running 4ghz @ 1.3v, or thereabouts.
Old May 22, 2009, 08:42 PM
CanadaRox's Avatar
The only 2.4 divider is with the 333MHz latch so I wouldn't be able to try any others. I can try a different latch if you think that would be of any use. The choices are 200/266/333/400.
Old May 22, 2009, 09:00 PM
Well, you can try..it's not what I want, but what you want...you want more FSB, so start tweaking.
Get HWinfo32, read teh ram's SPD, and put as many as those settings as is possible in the bios. sometimes the auto setting are what screws with you.
Even then, no guarantees..my QX would do that 1.3v/4ghz @ 12x333, 10x400, 9x445...no VTT changes, little chipset volt changes, and only really needed to adjsut a wee bit for ram clocks.
If you need 1.4v for those clocks...you cpu isn't that great, so you should really lower your expectations in FSB, and try just 333mhz and multi's to get you clocks, or go with what you know is already stable, and start upping the multi.
Old May 23, 2009, 07:58 PM
You can run the 1st setting robust graphics booster at auto.
you can set the frequency latch at auto it gives methinks more options on ram a b etc
You need to set more volt actuals than auto
Start back at default
my settings below BUT different stuff but you can get the drift.
Robust Graphics Booster ............... Auto
CPU Clock Ratio ..........................10x
Fine CPU Clock Ratio.....................0
CPU Frequency ...........................3.55(355x10)
Clock Chip Control
CPU Host Clock Control..................Enabled
CPU Host Frequency (Mhz) ............355
PCI Express Frequency (Mhz) .....100 lock
CPU Clock Drive...........................800 default
PCI Express Clock Drive................900 default
CPU Clock Skew (ps)....................0
MCH Clock Skew (ps)...................0
Performance Enhance................extreme
Extreme Memory Profile (X.M.P.).....profile 1
(G)MCH Frequency Latch............... 333
System Memory Multiplier ..............2.40b
Memory Frequency (Mhz) ..............800 852mhz. actual
DRAM Timing Selectable ................Manual
CAS Latency Time................5
tRCD .................................4
tRP'....................................4
tRAS..................................12
tRRD..........................................3
tWTR..........................................3
tWR............................................6
tRFC...........................................52
tRTP...........................................3
Command Rate (CMD) .................2 T
Driving Strength ............................1066
Channel A
Static tRead Value..........................7
tRD Phase0 Adjustment...................auto
tRD Phase1 Adjustment...................auto
tRD Phase2 Adjustment ..................auto
tRD Phase3 Adjustment...................auto
Trd2rd(Different Rank)....................auto
Twr2wr(Different Rank)...................auto
Twr2rd(Different Rank)...................auto
Trd2wr(Same/Diff Rank)..................auto
Dimm1 Clock Skew Control...............auto
Dimm2 Clock Skew Control...............auto
Channel B
Static tRead Value.........................7
Twr2rd(Different Rank)....................auto
Voltage Type.………... Manual
CPU
Load Line Enabled
CPU Vcore….……….....1.35000v
(cpu vid range 0.850v-1.36250v)
CPU Termination….....1.340v
CPU PLL…………………...1.500V
CPU Reference.…………0.848v
MCH/ICH
MCH Core…………….....1.240V
MCH Reference….…….0.728
MCH/DRAM Ref.….....0.980v
ICH Core…………...……1.200v
DRAM
DRAM Voltage ……....1.96v
DRAM Termination.0.980v
Channel A Reference 0.980v
Channel B Reference 0.980v
Advanced Settings
Limit CPUID Max. to 3....................Disabled
No-Execute Memory Protect............Enabled
CPU Enhanced Halt (C1E)................Enabled cpu throttles according to load on it.
C2/C2E State Support....................Disabled
x C4/C4E State Support..................Disabled
CPU Thermal Monitor 2(TM2) ..........Enabled
CPU EIST Function.........................Disabled
Virtualization Technology................Disabled Enabled if you use VMware/Virtual PC
Integrated Peripherals
Legacy USB Storage Detect ..............Enabled
Other settings
Lan 1 enabled
Lan2 disabled
green Lan disabled
on board serial port 1 disabled
on board parallel port 1 disabled
On board sata/ide device disabled
onboard 1394 enabled
sata port 0-3 native mode enabled
sata raid ahci disabled
All usb 1.0/2.0 controller enabled
have usb mouse and keyboard all that enabled
floppy drive1.44 enabled…….I use one
floppy 3 mode support disabled
delay for hdd 0
hdd smart drv disabled
initial display first PEG
first boot device OS hard drive
I use boot F12 key for anything else I need to call up
2nd boot device disabled
3rd boot device disabled
password check set up not used
cpu warning temp 70c/158f
cpu fan fail warning enabled
power fan fail warning disabled
sytem fan fail warning disabled
cpu smart fan control disabled have arctic freezer pro on want it on from get go.
pnp/pci all autos
Bios F-9
E-7300 cpu 45nm LGA 775
Thermal 65w
Buss 1066MHz.
Thermal Spec 74.1c
L2 Cache 3Mb.
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Old May 26, 2009, 04:09 PM
CanadaRox's Avatar
So I've tried using a 9.5x and 10x multi. With 9.5 I got to 3950MHz, and with 10x I could just under 3900MHz. So I thought maybe the motherboard just doesn't want to play nice with my QX9650 since it has a TDP of 130W. I've now put my X3350 (Q9450) in, and... *drum roll* failboat. 399FSB boots perfectly fine and is prime stable, but 400FSB wont post. My QX also doesn't need 1.4V for those clocks, but the droop in my board is pretty bad so it drops to 1.36, and I just wanted to be sure that wasn't causing any of the problems.
EDIT: I somehow managed to change something that let it work. I'm not exactly sure what as I was practically changing settings at random out of frustration. And then boom, posts. I might end up selling my QX9650 anyways if I can get some decent clocks out of my X3350 since university isn't going to be cheap next year (going to be going to Ryerson for engineering).
Q9450 + ep45-ud3p (F9) CTA Overclocking, Tweaking and Benchmarking 54 June 18, 2009 07:36 PM
[FS] Gigabyte GA-EP45-UD3P bigdee Buy/Sell & Trade 9 February 11, 2009 08:44 AM
Add parallel port on Gigabyte EP45-UD3P esanity Troubleshooting 2 January 10, 2009 01:42 PM
Gigabyte EP45 DS3R or UD3P? Dark-Colonel New Builds 6 December 3, 2008 06:03 AM
