Old May 21, 2009, 01:26 PM
kyle_L's Avatar
Default how much more nb voltage.
I'm playing around overclocking my q9550 and i realized that to go beyond 3.83 i need to up the north bridge voltage. im only shooting for 4.0. stock voltage is 1.10 on my board and in sitting at 1.14 at 3.83. how much higher should i go, and my ram will be running at 1002mhz at 2.0 not 1066mhz.if there is more info you need i will be happy to answer and thanks to all who can help me.
Gotta Love Timmies Coffee.
Old May 21, 2009, 01:28 PM
Most people will say 1.4-1.45 is max without some serious cooling.
Old May 21, 2009, 01:49 PM
gingerbee's Avatar
1.5 for me anything above that and water to the rescue.
Old May 21, 2009, 02:02 PM
kyle_L's Avatar
1.5 really. i didnt think people went that high. and it is watercooled so im good for cooling.
Old May 21, 2009, 02:08 PM
Lpfan4ever's Avatar
Guys, he's talking about NB voltage, not for the CPU (at least that seems like what you guys talking about. I don't think your NB goes that high, should it? )
Originally Posted by encorp
Code:
<firebane> slightly used
Old May 21, 2009, 02:13 PM
Yes we are aware its his NB and unless you have a nvidia chipset you can go as high as I have stated if not higher depending on your cooling methods.
Old May 21, 2009, 04:42 PM
Lpfan4ever's Avatar
Then I am mistaken. Just sounded like CPU volts to me, not NB.
Code:
Old May 21, 2009, 05:28 PM
gingerbee's Avatar
yes nb volts my max is 1.5 every where i have checked for intel max is 1.5. i think don't quote me on that i will check
Old May 21, 2009, 05:29 PM
gingerbee's Avatar
higher your fsb the more v your going to need
Old May 21, 2009, 07:54 PM
You should be able to hit a 500Mhz FSB with around 1.3-1.36 NB Volts
When I had a P5Q Deluxe, I was wondering why after 440Mhz FSB I needed a big jump in volts to the NB to keep it stable. Then I got a good tip, after you go past a certain FSB speed, the NorthBridge GTL setting will go out of wack on auto, you need to set it manually. Believe I was using 0.625 for NorthBridge GTL and 1.3 NB Volts to maintain 500Mhz FSB stability.
i7 voltage question gingerbee Overclocking, Tweaking and Benchmarking 12 March 9, 2009 11:04 AM
Voltage setup when OC Wurmer Overclocking, Tweaking and Benchmarking 8 February 20, 2009 04:36 PM
Voltage advice. encorp Overclocking, Tweaking and Benchmarking 3 November 20, 2008 11:49 PM
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 10:21 PM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
