Old May 22, 2009, 04:00 AM
gingerbee's Avatar
learn something new everyday thanks will check out
Old May 22, 2009, 12:44 PM
kyle_L's Avatar
hey thanks guys i got to 4 and occt doesnt fail right away anymore. im going to try 0.625 for NorthBridge GTL, and try for 500fsb tomorow. right now im running 475x8.5 for 4.02ghz. thanks for all your help and lets hope i can get this right.
Gotta Love Timmies Coffee.
Old May 22, 2009, 12:46 PM
Originally Posted by TerenceJ View Post
You should be able to hit a 500Mhz FSB with around 1.3-1.36 NB Volts
When I had a P5Q Deluxe, I was wondering why after 440Mhz FSB I needed a big jump in volts to the NB to keep it stable. Then I got a good tip, after you go past a certain FSB speed, the NorthBridge GTL setting will go out of wack on auto, you need to set it manually. Believe I was using 0.625 for NorthBridge GTL and 1.3 NB Volts to maintain 500Mhz FSB stability.
Depending on what board you have tho has different GTL settings and some don't allow much adjustment tho.
Old May 22, 2009, 03:08 PM
Well I wasn't meaning to sound like I was implying that every board and processor was exactly the same, I was simply giving him a heads up from research I have done with the same set up, and results others have had, as well as results I have had of simple ways to improve stability and performance so that his NB and CPU won't require crazy volts for Stability.
Old May 24, 2009, 03:35 PM
kyle_L's Avatar
well heres the best my proc could do. im still happy cause its only a c1.
Old May 24, 2009, 03:40 PM
CTA's Avatar
CTA CTA is offline
what is your vcore?
Old May 24, 2009, 05:39 PM
kyle_L's Avatar
didnt even see that it was missing. it is 1.400
Old May 24, 2009, 06:31 PM
CTA's Avatar
CTA CTA is offline
i see.. thats fair... like mine... almost...
i7 voltage question gingerbee Overclocking, Tweaking and Benchmarking 12 March 9, 2009 11:04 AM
Voltage setup when OC Wurmer Overclocking, Tweaking and Benchmarking 8 February 20, 2009 04:36 PM
Voltage advice. encorp Overclocking, Tweaking and Benchmarking 3 November 20, 2008 11:49 PM
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 10:21 PM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
