Old July 5, 2007, 12:19 PM
Cheator's Avatar
Originally Posted by Supergrover View Post
Well my vcore does go up and down, in bios, my gaurd (software monitoring) and with a multimeter, I can watch it go up and down in CPU-Z right now.
Really? Thats odd... even in the latest mine remains the same, for My DFI and my M2N-E. Sorry about that, guess I Was wrong.
Btw, nice to see you over here Supergrover! I've seen you around OCF if I am not mistaken.
Old July 5, 2007, 01:40 PM
magictorch's Avatar
Default cpuz
after watching cpuz for a bit it did change very now and again from1.44 to 1.47 or 1.51-although clock speed was very steady. seems ok in bios where its at 1.425 and i have the probe set to give an alarm if fluctuates too much. The ceramique seems to be working now a bit after cold/hot boots-30oc idle-44oc load max but i think it could do better. Will get a voltmeter to double check stuff. thanks for the advice guys.
E6750 throwing Vcore abnormality alert the_bandit87 Troubleshooting 1 August 22, 2007 10:08 PM
I'm now confused Vcore real or not? Delavan Overclocking, Tweaking and Benchmarking 4 June 12, 2007 04:56 AM
