  #31 (permalink)
Old May 22, 2009, 01:45 AM
CTA's Avatar
CTA CTA is offline
hmmm i believe 3.2ghz is stable (because i use occt and other many tasks at same time)
Code:
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Turbo
CPU Clock Ratio ..........................: 7
Fine CPU Clock Ratio.....................:.0
CPU Frequency ...........................: 3.220 ( anyhow it displays 3.233 )
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 460 Mhz
PCI Express Frequency (Mhz) .........:100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 800
PCI Express Clock Drive.................: 900
CPU Clock Skew (ps)....................: 0
MCH Clock Skew (ps)...................: 0
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: 333
System Memory Multiplier ..............: 2.4B
Memory Frequency (Mhz) ..............: [1104]
DRAM Timing Selectable ................: [Auto]
Standard Timing Control
CAS Latency Time........................:
tRCD .........................................:
tRP'...........................................:
tRAS..........................................:
Advanced Timing Control
tRRD...........................................:
tWTR..........................................:
tWR............................................:
tRFC...........................................:
tRTP...........................................:
Command Rate (CMD) ....................:
Driving Strength Profiles
Driving Strength ............................:
Channel A
Static tRead Value.........................:Auto
 tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
 tRD Phase2 Adjustment .................:Auto
 tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto  ps
Dimm2 Clock Skew Control...............:Auto  ps
Channel B
Motherboard Voltage Control
Load-Line Calibration.……….............: Enable
CPU
CPU Vcore….………......1.250V*.......: 1.3815
CPU Termination…..... 1.200V*.......: 1.34
CPU PLL…………………....1.500V*.......: 1.5
CPU Reference………....0.760V*.......: [Auto]
MCH/ICH
MCH Core…………….....1.100V...........: 1.36
MCH Reference….…….0.760V...........; [Auto]
MCH/DRAM Ref.…......0.900V...........: [Auto]
ICH I/O……………….....1.500V............: [Auto]
ICH Core…………...……1.100V............: [Auto]
DRAM
DRAM Voltage ……....2.060V............: 2.1
DRAM Termination .…0.900V............: [Auto]
Channel A Reference 0.900V............: [Auto]
Channel B Reference 0.900V............: [Auto]
too much voltage?
realtemp; 55,53,53,51 << ouch... eh?
soon i will try 8x... if its stable then i guess to lower cpu term and mch except vcore... and see what happens...
  #32 (permalink)
Old May 22, 2009, 05:45 AM
yep looks good, I see you got your ram multiplier at 2.4, making your ram run at 1104Mhz, so if your system goes unstable that might be one reason, other than that,
for 3.2Ghz you could prob use less volts. But hey good your system seems more stable now. Maybe try lowing your MCH, and CPU Termination volts now. And if its still stable, you can up the CPU multiplier, and if it goes unstable, the only thing it needs is CPU VCore volts
  #33 (permalink)
Old May 22, 2009, 01:14 PM
CTA's Avatar
CTA CTA is offline
with 8x cpu multiplier and 1.3815v ( display as 1.36) is not stabled... so i jump to 1.4125 because 1.4065 is not stable... :\
it seems it stables since i am still running OCCT for 1 and 20 minutes... plus i use many applications (watch "stealthisfilm!" and etc)
i think i will try 1.4 to find out if its stable... if its stable then i will raise more fsb... maybe 1 or 2mhz... if its not stable then i will stop... its not bad...
yes i use 2.4x as 1104mhz... but i think i have 5-7-7-25 (not sure why but its auto) i will overclock it soon...
  #34 (permalink)
Old May 23, 2009, 07:26 PM
CTA's Avatar
CTA CTA is offline
Code:
Advanced Settings
CPU Clock Ratio ..........................: 8
CPU Frequency ...........................: 3.686
Clock Chip Control
Channel A
Channel B
CPU
CPU Vcore….………......1.250V*.......: 1.41875
MCH/ICH
DRAM
it seems too much... i will decease MCH to 1.32, cpu term to 1.34 and ram muliplier to 2x (920mhz)
those pictures are really odd... and occt's temperature is different than realtemp by 10'c.... if realtemp is reading as 10-on everything... for example 71-10 = 61'C =realtemp...
  #35 (permalink)
Old May 23, 2009, 08:37 PM
Hey you get it stable at 3.6?
  #36 (permalink)
Old May 23, 2009, 09:02 PM
CTA's Avatar
CTA CTA is offline
yes, but i feel its not right...
right now i use 1.34 for MCH, 1.34 for cpu term and use 1.4 for vcore...
i dont think lower ram multiplier will help very much... willn't it?
  #37 (permalink)
Old May 23, 2009, 09:05 PM
ya maybe your just getting near your CPU's limit. Glad to see you have some progress though
  #38 (permalink)
Old May 23, 2009, 09:45 PM
CTA's Avatar
CTA CTA is offline
i hope its not cpu's limitation... i wanna more ;[
i think about to get q9550 or better... eh?
  #39 (permalink)
Old May 24, 2009, 04:17 AM
martin_metal_88's Avatar
Getting a Q9550 would not change thwe world exept if you want to go up to 3.8 or more fast, and your board can handle it. Now I have something to tell you. I set my ram at the same speed has you ( we have pretty the same config ) and it was little unstable and finally it take under 2 hour my ram start to fail memtest. Now she is dead :( lol :) time for new one ( already receive, ordered yesterday thx NCIX. ) I try the same with my new G.skill more stable but little unstable again try to set ram at 5-5-5-15 1066 to seee if you can raise up little more. and keep a fan on you pC side to be sure of temp whe trying it, after it being stable remove the fan and look at the temp.
Ask for more ;) my pm box is always open
  #40 (permalink)
Old May 24, 2009, 09:35 AM
Robust Graphics Booster ............... Auto
CPU Clock Ratio ..........................10x
Fine CPU Clock Ratio.....................0
CPU Frequency ...........................3.55(355x10)
Clock Chip Control
CPU Host Clock Control..................Enabled
CPU Host Frequency (Mhz) ............355
PCI Express Frequency (Mhz) .....100 lock
CPU Clock Drive...........................800 default
PCI Express Clock Drive................900 default
CPU Clock Skew (ps)....................0
MCH Clock Skew (ps)...................0
Performance Enhance................Extreme
Extreme Memory Profile (X.M.P.).....Profile 1
(G)MCH Frequency Latch............... 333
System Memory Multiplier ..............2.40b
Memory Frequency (Mhz) ..............800 852mhz. actual
DRAM Timing Selectable ................Manual
CAS Latency Time................5
tRCD .................................4
tRP'....................................4
tRAS..................................12
tRRD..........................................3
tWTR..........................................3
tWR............................................6
tRFC...........................................52
tRTP...........................................3
Command Rate (CMD) .................2 T
Driving Strength ............................1066
Channel A
Static tRead Value..........................7
tRD Phase0 Adjustment...................auto
tRD Phase1 Adjustment...................auto
tRD Phase2 Adjustment ..................auto
tRD Phase3 Adjustment...................auto
Trd2rd(Different Rank)....................auto
Twr2wr(Different Rank)...................auto
Twr2rd(Different Rank)...................auto
Trd2wr(Same/Diff Rank)..................auto
Dimm1 Clock Skew Control...............auto
Dimm2 Clock Skew Control...............auto
Channel B
Static tRead Value.........................7
Twr2rd(Different Rank)....................auto
Voltage Type.………... Manual
CPU
Load Line Enabled
CPU Vcore….……….....1.35000v
(cpu vid range 0.850v-1.36250v)
CPU Termination….....1.340v
CPU PLL…………………...1.500V
CPU Reference.…………0.848v
MCH/ICH
MCH Core…………….....1.240V
MCH Reference….…….0.728v
MCH/DRAM Ref.….....0.980v
ICH Core…………...……1.200v
DRAM
DRAM Voltage ……....1.96v
DRAM Termination.0.980v
Channel A Reference 0.980v
Channel B Reference 0.980v
Advanced Settings
Limit CPUID Max. to 3....................Disabled
No-Execute Memory Protect............Enabled
CPU Enhanced Halt (C1E)................Enabled cpu throttles according to load on it.
C2/C2E State Support....................Disabled
x C4/C4E State Support..................Disabled
CPU Thermal Monitor 2(TM2) ..........Enabled
CPU EIST Function.........................Disabled
Virtualization Technology................Disabled Enabled if you use VMware/Virtual PC
Integrated Peripherals
Legacy USB Storage Detect ..............Enabled
Other settings
Lan 1 enabled
Lan2 disabled
green Lan disabled
on board serial port 1 disabled
on board parallel port 1 disabled
On board sata/ide device disabled
onboard 1394 enabled
sata port 0-3 native mode enabled
sata raid ahci disabled
All usb 1.0/2.0 controller enabled
have usb mouse and keyboard all that enabled
floppy drive1.44 enabled…….I use one
floppy 3 mode support disabled
delay for hdd 0
hdd smart drv disabled
initial display first PEG
first boot device OS hard drive
I use boot F12 key for anything else I need to call up
2nd boot device disabled
3rd boot device disabled
password check set up not used
cpu warning temp 70c/158f
cpu fan fail warning enabled
power fan fail warning disabled
sytem fan fail warning disabled
cpu smart fan control disabled have arctic freezer pro on want it on from get go.
pnp/pci all autos
Bios F-9
E-7300 cpu 45nm LGA 775
Thermal 65w
Buss 1066MHz.
Thermal Spec 74.1c
L2 Cache 3Mb.
heres some settings above.
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
[FS] Gigabyte GA-EP45-UD3P bigdee Buy/Sell & Trade 9 February 11, 2009 08:44 AM
Gigabyte EP45 DS3R or UD3P? Dark-Colonel New Builds 6 December 3, 2008 06:03 AM
Gigabyte GA-EP45-UD3P Review Comment Thread MAC CPU's and Motherboards 16 November 27, 2008 06:21 PM
