Old May 20, 2009, 11:26 PM
it still applies pretty good pressure, be careful not to put too much, don't want to damage that nice board, give the OC'ing a shot first, and see how temps look, Good luck
Old May 21, 2009, 12:29 AM
CTA's Avatar
CTA CTA is offline
just curious... which to use disable, standard or turbo for Performance Enhance?
oh yeah, i tried 444mhz x6, and 1066... i will raise more...
Old May 21, 2009, 01:29 AM
CTA's Avatar
CTA CTA is offline
460 at 1.2815v (just use OCCT for 10 mins... i dont want to use 2 hours)
so i try to jump to 470 and i have to change 1.2815 to 1.3815v or it can't start vista (freeze)
NOT STABLE
Code:
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Turbo
CPU Clock Ratio ..........................: 6
Fine CPU Clock Ratio.....................:.0
CPU Frequency ...........................: 2.82
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 470 Mhz
PCI Express Frequency (Mhz) .........:100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 800
PCI Express Clock Drive.................: 900
CPU Clock Skew (ps)....................: 0
MCH Clock Skew (ps)...................: 0
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: 333
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ..............: [940]
DRAM Timing Selectable ................: [Auto]
Standard Timing Control
CAS Latency Time........................:
tRCD .........................................:
tRP'...........................................:
tRAS..........................................:
Advanced Timing Control
tRRD...........................................:
tWTR..........................................:
tWR............................................:
tRFC...........................................:
tRTP...........................................:
Command Rate (CMD) ....................:
Driving Strength Profiles
Driving Strength ............................:
Channel A
Static tRead Value.........................:Auto
 tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
 tRD Phase2 Adjustment .................:Auto
 tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto  ps
Dimm2 Clock Skew Control...............:Auto  ps
Channel B
Motherboard Voltage Control
Load-Line Calibration.……….............: Enable
CPU
CPU Vcore….………......1.250V*.......: 1.4
CPU Termination…..... 1.200V*.......: 1.3
CPU PLL…………………....1.500V*.......: 1.5
CPU Reference………....0.760V*.......: [Auto]
MCH/ICH
MCH Core…………….....1.100V...........: 1.3
MCH Reference….…….0.760V...........; [Auto]
MCH/DRAM Ref.…......0.900V...........: [Auto]
ICH I/O……………….....1.500V............: [Auto]
ICH Core…………...……1.100V............: [Auto]
DRAM
DRAM Voltage ……....2.060V............: 2.0
DRAM Termination .…0.900V............: [Auto]
Channel A Reference 0.900V............: [Auto]
Channel B Reference 0.900V............: [Auto]
i lower 2.4x to 2.0x (940) and 2.0v for stable...
if i use 2.4x (1128) then i must rasie 2.0 to 2.1v... but not stable and i might need to raise more cpu voltage... is it too much?
thank you again...
Old May 21, 2009, 02:30 AM
should be enough on your Vcore, everything looks ok, except, I see you have your MCH core set to 1.3
If you look at my printscreenshots, for 495Mhz and 500Mhz FSB, I was using 1.34
you could even go to 1.36 MCH core
Sometimes the CPU's have a FSB wall, but these newer 45nm quads seem to be able to push 500 ok.
Old May 21, 2009, 02:39 AM
CTA's Avatar
CTA CTA is offline
ok what is maximum voltage of mch?
now i will go back 1.4v vcore to 1.28135v and rasie 1.32v... right? if its not unstable then raise vcore until 1.4v.... if fail then raise mch 1.32 to 1.34 and go so...?
i really hope its not fsb wall >_>;
Old May 21, 2009, 06:44 AM
martin_metal_88's Avatar
1.4 Is realy High for a 9450 or a 9550, the chip is ok to take it but not 24/7. I sugest 1.325 for 24/7 OC. And don't worry with my Q9550 and my EP45-UD3P i'm running 3.8 on air with a vendetta 2 and maximum of 41 celcius. You don't need to be watercooled if your chip is a little good. You should be abble to go up to 500 FSB easy to if you have good memory I do it like a charm with Mushkin XP2 1066 and now I have reach 525 with G.skill and keep pushing it. ( but my proc is little hot max of 54 celcius full load ).
Ask for more
Old May 21, 2009, 02:24 PM
CTA's Avatar
CTA CTA is offline
ok... i will keep it in my mind to set 1.325 as maximum daily oc...
my memory is similar to your...
Old May 21, 2009, 05:49 PM
Keep in mind, you might set it to 1.4 in the BIOS, but it might only read as 1.36 when your in Windows on CPU-Z
If your setting to 1.325 in BIOs, you might only have 1.28 on the core, it won't always set perfectly. I know mine are usually .03 lower.
  #19 (permalink)
Old May 21, 2009, 06:00 PM
CTA's Avatar
CTA CTA is offline
that makes a sense... but is it really bios's fault?
i tried 1.34 on MCH (1.2815 on vcore)... it still unstable at currently vista but i suspected that if the vista can't start then i should raise voltage of mch... but what about if i also raise cpu pll? from 1.3 to 1.34 or 1.36?
  #20 (permalink)
Old May 21, 2009, 07:30 PM
check my Pictures I posted above, CPU PLL was the same in all of them, 1.5 which is default
you can bump up CPU Termination a little to 1.32-1.34
MCH core you can go up to 1.36 no problems,
when you CPU gets up to about 3.6-3.8Ghz it might need around 1.34 Vcore(as read in windows. Not all chips run at the nice low Vcore the other person mentioned.
You can see in my pictures I posted for you, what Vcore I had for CPU speeds, and mine was a chip that took a little more volts. As long as your max temp under load is under 70C your fine.
[FS] Gigabyte GA-EP45-UD3P bigdee Buy/Sell & Trade 9 February 11, 2009 08:44 AM
Gigabyte EP45 DS3R or UD3P? Dark-Colonel New Builds 6 December 3, 2008 06:03 AM
Gigabyte GA-EP45-UD3P Review Comment Thread MAC CPU's and Motherboards 16 November 27, 2008 06:21 PM
