June 27, 2008, 09:07 AM
 | Rookie Level: 4 - 11 points to level up | |
Originally Posted by 3.0charlie Find out what is the default Vcore of your E6600. Set it at that value. Un-sync your RAM - that OCZ is not known to OC very well.
Start with that. Raise the FSB slowly (20 MHz), load Windows, start Orthos for 15-20 minutes. Check temps - max. 55ish C. If stable, raise FSB, re-load Windows, start Orthos, verify temps again. Stable? Wash again...
Once Windows won't load, raise Vcore slowly (max. 1.40 on air I believe - don't take my word for it) and start all over.
BTW, you got one heck of a rig! | By following these instructions you should be able to get quite a good OC
__________________ Antec P180 | E6300 @ 3.01Ghz(Scythe Ninja Rev.B) | Asus P5N32-E SLI PLUS | 2gb OCZ PC2-8000 @ 860mhz | EVGA 8800GTX 768mb (630/984) | Seasonic S12 Energy Plus (550W) | Samsung 226BW| |
