Old May 14, 2009, 07:31 PM
Default Intel Burn Test 1.92 Any Good?
Hey guys,
I've been surfing around and found the Intel Burn Test, according to the manual it says:
1. More accurate than Prime95 Small FFTs/Blend.
2. Takes less time to tell if your CPU/RAM is unstable than Prime95 (usually
something like 8 minutes Linpack vs 40 hours under Prime95).
3. Use the same stress-testing engine that Intel uses to test their products
before they are packed and put on shelves for sale.
So is it true? or should I avoid this and stick to prime 95?
Old May 14, 2009, 07:43 PM
Delavan's Avatar
Good question!
I can't wait to find out what the answer is!
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old May 14, 2009, 08:10 PM
Some say yes.
Some say no.
I personally do not like it.
Old May 14, 2009, 09:06 PM
JD JD is offline
I prefer LinX myself for Linpack testing. Better GUI/options.
I find it fails much faster than Prime95, but that's just one man's opinion...
Old May 14, 2009, 09:11 PM
I find folding@home the best cpu stability test i've ever run. Ive had OCCT run for hours,and Prime will run without hickups,but fire up F@h and if its shakey its lucky to run for 5 min. I still like Prime if i'm testing cpu+ram testing though.
Old May 14, 2009, 09:14 PM
geokilla's Avatar
I'm not fond of Intel's Burn Test either. I just run 2 to 3 hours of OCCT plus some Memtest, then I call myself stable. Some may say it's not stable, but we all have our definition of what's stable.
There is a good thing about Intel's Burn Test. It creates EXCESSIVE heat for the CPU.
Old May 15, 2009, 05:05 AM
gingerbee's Avatar
don't likey at all
Old May 15, 2009, 06:18 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
I'm not too crazy about it either. It is GREAT for testing heatsink performance but other than that? Not so much.
IMO, a good stability test is never just one program. Rather, you need to use a combination of programs such as Prime 95 and OCCT. Even though it might be perfectly stable in both of those, is it 3D stable? That is a huge question for gamers as me and many other people have run Prime / OCCT for hours on end without an error and then fire up 3DMark or a game and...BAM, instability.
I would suggest you check out some of the motherboard reviews here at HWC and read the Testing Methodology section where we cover what we consider "stable".
Old May 15, 2009, 07:52 AM
HuttFuzz's Avatar
FYI, i use LinX (which is Intel Burn Test), for about 20 passes. Then i do Prime95 Blend for 2 hours and when i have time i will run Prime95 Small FFT overnight. That is a good mix.
Throw in some benchmark like 3dMark and you can't be better.
Core i7 920(D0) @4.0 1.212v | Gigabyte EX58-UD3R | OCZ Gold 3x2GB CL8 | Silverstone FT01-BW | TRUE 1366-RT | eVga GTX275 FTW (713/1512/1260) | Corsair TX850w | Hitachi 500GB | Seagate 7200.11 750GB | Dual Screen (Dell 2208wfp & Viewsonic VP930b)
Old May 15, 2009, 10:39 AM
rjbarker's Avatar
LinX Linpack 0.5.8 - All Available Memory - 25 passes
P95 Blend overnight to 10 hrs
If I pass both, i'm solid.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
intel Smackover - any good? dadzilla CPU's and Motherboards 6 April 19, 2009 07:51 PM
Testing Intel Burn Test 64 and Prime 95 64 (Help?) appplejack Overclocking, Tweaking and Benchmarking 1 January 11, 2009 03:53 PM
could i burn out my mobo by....? andynerd CPU's and Motherboards 9 December 28, 2008 09:29 PM
Good test programs for new rigs. chouchou O/S's, Drivers & General Software 6 October 22, 2008 05:01 PM
Burn time enzeo Storage 3 July 24, 2007 11:13 PM
