Old May 14, 2009, 07:11 PM
Default Overclocking my system
Hey guys I heard about the site from a youtube video. I have absolutely no idea how to OC my computer, but maybe you guys can help me. I bought a 2.67 core i7, nvidea geforce gtx 285, 6 gig ddr3 8 8 8 24 ram ( 1600), and my motherboard is p6t deluxe v2 x58. Can someone plz help me, I have no idea... And I also haave a program that seems to OC the graphics card itself, called EVGA precision? I tryed to go into the bios and as soon as i got there i was like woah. I also have no idea how hot my computer is running...
Old May 14, 2009, 07:18 PM
gingerbee's Avatar
you have to do a lot of reading sure if you are new to the bios read read read there are many guides online about overclocking. i suggest you read some of them before you start.
it just sounds like you are very new to the bios so take it slow. there is not a one recipe fits all for overclocking. starting with an i7 for a first overclock might be a little dangerous for the pocket book. and i am not trying to discourage you just takes a lot of reading so get started. and good overclocking.
Old May 14, 2009, 07:23 PM
Lol... is it relative to the motherboard? I'm confused? Because when i went to bios it looked differnet on youtube video...
Old May 14, 2009, 07:27 PM
Nademon's Avatar
+1 gingerbee.
When I got into it, I was a little intimidated by all the bios settings and what they meant and did. Reading up is really the key and taking it slow....very very slow. If you OC a bit and see great results with an increase in voltage on some setting, don't get carried away and start boosting the voltage in huge increments and expect it to work. Easy to kill your system that way. I'm not gonna lie to you, there's a lot to learn and understand, but get familiar with the basics first (CPU ratio's, FSB or whatever it's called now for i7..I think it's QPI, ram timings, volts, etc.). Theres a lot of good info out there and on this very forum too.
Happy overclocking! It really is a lot of fun once you get the hang of it and it doesn't hurt getting thousands of dollars worth of extra performance by putting in the time to tweak!
REFS:
My Heat, Ebay, RedFlagDeals
Rig 1: CM HAF - Rampage Extreme - QX9650 - OCZ Gladiator Max - 4GB Mushkin DDR3 1600 - GTX280 - 2xBarracuda 500GB - 1xBarracuda 250GB - Pioneer DVD - Corsair 1000HX
Rig 2: Thermaltake Armor - P5K-E - E3110 - TRUE w/ 2 120's - 4GB Ballistix DDR2 1066 - 9800GX2 - 2xBarracuda 250GB - Pioneer DVD - Corsair 620HX
Rig3: Antec 900 - P5K-E/Wifi - E5200 - OCZ Vendetta 2 - 4GB OCZ DDR2 800 - 2x 8800GTS's - 1xWD Caviar 80GB - Pioneer DVD - OCZ 650W PSU
Old May 14, 2009, 07:30 PM
alright I'll see what i can do.... i wish i had a friend who knew what they were doing... Thanks guys :). Ill take it slow... my system cost 2.5k i agree its not worth being careless.
Old May 14, 2009, 08:34 PM
stoanee's Avatar
The biggest things to watch are overvolting=kill your components
& overheating=kill your components
Use the power of google for info and when you are trying different settings keep a log of what you are doing to track the good and the bad settings. It will save you time when you are doing the inevitable resets. Have fun!
heatware
Needs some help overclocking lanken123 Overclocking, Tweaking and Benchmarking 0 April 21, 2009 11:51 AM
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 28, 2008 12:05 AM
Overclocking P4 1.8 Kassela Overclocking, Tweaking and Benchmarking 1 December 27, 2007 12:28 PM
Need help overclocking further Kessler Overclocking, Tweaking and Benchmarking 15 December 5, 2007 06:09 PM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
