Old May 13, 2009, 08:18 PM
somecanadianguy's Avatar
Default CPU PLL...?
I'm still working on OC'ing my i7 920...
After doing a bunch of reading about voltages I'm still a little confused.
CPU PLL, for example, is something people normally suggest raising if an overclock is not stable.
I have read one small guide that says lowering it may help stability...
Default value is 1.8V.
A mod on a gigabyte forum suggested 1.75V as min, but my motherboard (ex58-ud3r) only lets me choose .1V increments so I chose 1.7V.
I was able to run Prime95 Blend (64bit) for 20hrs before I stopped it.
Temps topped at 75c when the furnace was on... average around 70c.
Would there be some reason for me to use 1.8 CPU PLL if 1.7 runs stable?
Old May 14, 2009, 12:23 AM
No, I've talked to many who have had good luck undervolting PLL...even during extreme overclocking. ;)
Old May 14, 2009, 12:48 AM
Realityshift's Avatar
I agree if you can run anything at a lower voltage while remaining stable DO IT, less stress on the system and probubly less heat too. 20 hours is a pretty damn stable overclock IMHO.
The Builders Hammer
Old May 14, 2009, 07:08 AM
HuttFuzz's Avatar
It's very interesting to see that. I say leave it that way. I'll try it myself tonight. What are your clocks (bclk x multi), vcore and QPI voltages?
Core i7 920(D0) @4.0 1.212v | Gigabyte EX58-UD3R | OCZ Gold 3x2GB CL8 | Silverstone FT01-BW | TRUE 1366-RT | eVga GTX275 FTW (713/1512/1260) | Corsair TX850w | Hitachi 500GB | Seagate 7200.11 750GB | Dual Screen (Dell 2208wfp & Viewsonic VP930b)
Old May 14, 2009, 11:13 AM
I found it quite intersting myself.
Not sure why it works, but it does.
I'm at 200bclk x 19
Vcore 1.34375V; QPI Vtt 1.320V in BIOS.
CPUz was showing Vcore 1.328 idle and 1.312 to 1.296 under load.
Load-Line Calibration was enabled (still doing some reading on that).
Passed 20Hrs Prime Blend, I was using the internet too for most of it... could even run superpi and wPrime at the same time so I'd say it's pretty stable.
I'll likely try and see if I can lower QPI a bit, but I'm pretty happy with this OC.
Not bad considering I really just started learning.
This site has sure helped me a lot
*edit*
Lowered QPI Vtt to 1.300V and got a BSOD after about 30mins Prime Blend and surfing.
CPU use @ 57% and inactive processe use 93% of the CPu WTH ebdoradz Off Topic 6 February 26, 2008 07:34 PM
