Why are idle volts so much higher than load volts
I just found out theres the Vdroop thing. Is there any settings i can change to lower the idle volts?
The higher Volts for the CPU the higher the Vdroop
CPUZ V at idle
CPUZ V at load
My settings
Code:
[BIOS SETUP] O.N.E
Over-Clocking Navigator [Manual OverClock]
Intel(R) SpeedStep(tm) : Disabled
Ratio CMOS Setting : x9
CPU Frequency Setting : 333
Over Clock Retry Count : 2
FSB Compensation: Disable
FSB(Bsel) To NorthBridge Latch : 1066
DRAM Frequency : 999
DDR2 Enhance Mode : Disabled
DRAM Timing Configuration
DDR2 RCOMP Configuration : Auto
Static tREAD Value : Auto
Configure DRAM Timing by SPD : Enabled
Clock Gen Configuration
PCIE Frequency Setting : 100
CPU Clock Skew Control : Auto
(G)MCH Clock Skew Control : Auto
CPU Clock Driving Control : Auto
Voltage Configuration
CPU Voltage : +0.150
DDR Voltage : +0.200
Chipset Voltage : +0.100
FSB Voltage : +0.100
CPU Core1 GTL Ref Voltage : 0.63*VTT
CPU Core2 GTL Ref Voltage : 0.67*VTT
MCH GTL Ref Voltage : Auto
CPU PLL Voltage : 1.5v
what do those clock gen configurations do? And what settings should be used for the autos ?
