Old May 11, 2009, 12:55 PM
Default Ram Speed on CPUZ... Help..
Hi guys,
On CPUZ it says my memory is running 255MHZ (1:1) does that mean its running 510Mhz??
Sorry for noob question, I just want to make sure..
Old May 11, 2009, 01:04 PM
Supergrover's Avatar
Yes, click on the memery tab it should show the speed as 510.
Old May 11, 2009, 01:17 PM
On mines it says 255Mhz 1:1, in bios its set to 510Mhz dual channel
Old May 11, 2009, 01:23 PM
3oh6's Avatar
Hardware Canucks Reviewer
yes, 255MHz = DDR2-510...but DDR2-510 != 510MHz.
there is a difference between DDR speeds and MHz. DDR2-510 for instance is just a made up number by marketing departments to make memory seem faster. 255MHz is the actual frequency of the memory, it is just "effectively" running at DDR2-510 because it moves data twice per clock cycle. manufacturers now like to use the terms DDR3-2000MHz or DDR2-1066MHz when the reality is that those terms are oxymorons...they are impossible.
many forum users like to call DDR2-800 as 800MHz or DDR2-1066 as 1066MHz when they really are just 400MHz and 533MHz. so long story short, yes your memory is running at DDR2-510 and 255MHz, because they are one in the same.
Old May 11, 2009, 01:24 PM
Ah Ic thanks, just had me confused because before it was showing 510Mhz but I think it was 1:2.. anyway thx for quick response :]
Old May 11, 2009, 01:28 PM
3oh6's Avatar
that makes sense if the memory ratio was set to 1:2 because it would then make your memory run at twice the HTT of 255. so your memory would have been running 510MHz which is equal to DDR2-1020. in the screen shot above, it is running at 1:1 with the HTT which is 255, that is why it is running at 255MHz.
Old May 12, 2009, 11:20 AM
gingerbee's Avatar
so true 3oh6 the sales mens pitch ddr 800 ha ha
Q9650 Core speed in CPUZ Maculosa Troubleshooting 7 February 23, 2009 06:06 PM
Question About Ram Speed dadzilla RAM 1 October 22, 2008 09:35 AM
Ram speed rating vs actual low351 RAM 7 February 21, 2008 11:33 AM
RAM Speed lower than rating CasheKicker RAM 10 February 18, 2008 03:39 PM
