Old May 1, 2009, 08:41 AM
ChuckleBrother's Avatar
Default Voltage Questions - i7 920
Running on my i7 920, Foxconn Bloodrage board and overclocking this thing seems to be easy as pie but, I have no idea if my voltages are safe.
I hit 3.99Ghz this morning(by mistake) with the following settings:
bclk - 190
multi - 21
vcore - 1.392(1.2575 in Bios)
vdimm - 1.66(1.65 in Bios)
My VTT/etc is all on auto so it keeps the proper differential from the vdimm, but is all this safe? Am I risking any degradation of my chip? Please advise.
"...you play a mean banjo"
Old May 1, 2009, 08:55 AM
matsta31's Avatar
you can always refer to this for a quick baseline :
Intel® Core? i7 Processor I7-920 - SLBCH
look at the VID voltage range. These are basically the voltage range at wich intel feels ok sending a stock I7 920 and giving it the normal warrenty.
I run mine at 1.392 (according to CPU-Z). What is up with the Bios vs windows voltage for your Mobo ?
Sold hardware again.....
Currently using WHS hardware....
Old May 1, 2009, 08:59 AM
My board has a feature that compensates for vdroop basically causing my voltage in Bios to be substantially lower.
I've read that the uncore is just as bad for killing a cpu, is there any way to check my current uncore voltage? I left it at default but I'd still like some peace of mind.
Old May 1, 2009, 09:09 AM
matsta31's Avatar
I use my Bios reading for the uncore, since my Windows vs Bios numbers dont differ really much.
Yes, to much uncore voltage can kill the CPU, specially when there is a big differential between Dimm voltage, uncore and v-core.
As a general rule of thumb, if you really want to be safe, try not to use more than 1.65V for the ram and keep the uncore at .5 V for the Ram at max. Wich you are currently doing, so I would not bother to much.
If you relly want to be safe, bring the OC back a bit and keep the voltage in intel guidelines. Altough I would not worry to much with your current settings.
Old May 1, 2009, 09:17 AM
zlojack's Avatar
Temps ok?
Old May 1, 2009, 09:45 AM
gpu stressed and going on 2 hours of P95 and we're looking at:
64/63/61/59
Fairly decent all things considered.
Old May 1, 2009, 10:37 AM
matsta31's Avatar
temps are ok, I would leave it like that, but in the end, you need to decide if you are confortable with it.
Now, you need to FOLD !
i7 voltage question gingerbee Overclocking, Tweaking and Benchmarking 12 March 9, 2009 11:04 AM
920 OC Voltage questions SugarJ Overclocking, Tweaking and Benchmarking 3 March 5, 2009 09:45 AM
Voltage setup when OC Wurmer Overclocking, Tweaking and Benchmarking 8 February 20, 2009 04:36 PM
Over Voltage a35599 Overclocking, Tweaking and Benchmarking 6 February 26, 2008 10:21 PM
What is Stock Voltage? mattydies Video Cards 10 October 19, 2007 09:01 PM
