<~----> Overclocking E8400 - Hardware Canucks
Old April 18, 2009, 10:34 AM
Default Overclocking E8400
Hi im new here and new to overclocking i need help
right now "so far" i have 3.8ghz stable 423*9 1700mhz fsb 2.66C
specs
E8400 C0 1.28125V(BIOS) 1.216v(WINDOWS)
EP45-DS4P mobo (p45)
2x2gb mushkin 1066 mhz memory 5-5-5-15
temps 33-47
i tried raising the voltages to a bit above 1.3v to get to 4 ghz, i can get to windows but as soon as i run Orthos it fails 5 seconds in, what do i need to do?
thanks
Old April 18, 2009, 10:47 AM
gingerbee's Avatar
max vcore is 1.36 i think so. ram v and northbridge v would help
Old April 18, 2009, 10:48 AM
Gellidius's Avatar
increase the voltage step by step, in small increments, testing for stability every time.
i'm sure someone else will be of greater help than i, as i've done this only once.
Jacques
Ego cogito, ergo deus non est.
Old April 18, 2009, 11:00 AM
is there even a real world difference between 3.7ghz and 4ghz? cause i can keep my stock voltage at 3.7ghz should i just leave it at 3.7?
Old April 18, 2009, 11:25 AM
you know what, 3.8 is a nice number,theres only one thing i wanna know, how long will this CPU last me with these settings, i want atleast 3 years, will it survive?
Old April 18, 2009, 11:27 AM
gingerbee's Avatar
almost none besides benchmarks from what i can tell. by stock voltage do you mean auto. cause sometimes auto go's way to high imo.
gingerbee's Avatar
and if your happy with it then that's all that matters?. keep it there
Old April 18, 2009, 12:49 PM
geokilla's Avatar
Even though max vcore is 1.36V, many have pushed their CPUs over this limit. I'm personally comfortable with going up to 1.4Vcore in CPU-Z. Any higher then I'll start to worry.
@Sharp. You can always use OCCT and stress test the CPU for 3 hours. To me, if it passes OCCT for more than 3 hours, then it's stable.
If you've been raising the Vcore and still getting errors while keeping the CPU speed the same, try raising the FSB and MCH voltage by 0.1v. If your CPU becames stable after raising either the FSB or MCH voltage, then it could mean that there wasn't enough voltages going to either the FSB or MCH.
Old April 18, 2009, 01:19 PM
Realityshift's Avatar
Max VID is 1.36 not max vcore, if you read up on your product documentation it lists 1.45 as max safe voltages hence the reason we have been running our c2ds over 1.36 vcore. Just means that these CPUs will not come with a VID of higher then 1.362 (some very unlucky people out there if they got anywhere close to that number =(..) Id have to say you have a very good overclock at a decent Vcore right now so if your happy with it there wont be any real world difference between what you have and 4ghz.
The Builders Hammer
Old April 18, 2009, 02:03 PM
Silvgearx's Avatar
3.7 GHZ vs 4GHZ?
Differences? Yes, for CPU hungry games you will see an increase in frames/second and video encoding you will shorten the times by a few minutes to hours
I lost 30FPS with a 2.66ghz cpu compared to a 3.8ghz
Overclocking e8400 on a p5Q pro serenity CPU's and Motherboards 10 February 4, 2009 03:57 PM
A few questions on overclocking my E8400 and 4870 lanken123 Overclocking, Tweaking and Benchmarking 16 January 11, 2009 07:49 PM
Need help overclocking my E8400 please BlueRice Overclocking, Tweaking and Benchmarking 3 December 12, 2008 02:27 PM
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 11:24 AM
Problems with Overclocking my e8400 Tumdace Overclocking, Tweaking and Benchmarking 66 March 12, 2008 01:44 AM
