Old April 17, 2009, 11:37 AM
Default Best program to overclock an AMD X2
Hey, my dad has got an Athlon 4200 X2 2.21 ghz on a GA-MA69VM-S2 Gigabyte board... Now I looked in the bios and I didnt see anyway to overclock from there so I must assume that you have to overclock with a program. I know gigabyte as their easytune software, but is that the best program to use? I do not know anything about amd overclocking or program overclocking. I have an overclocked intel processor myself.
I think I read somewhere that The athlon x2s dont overclock as well as the intel c2d do, so I am also wondering if what i get out of an overclock will really be worth it.
any help is appreciated,
kyle
Old April 17, 2009, 02:04 PM
dataxpert's Avatar
the boad should came with easytune 5 it's a windows base software for overclock, but honestly I prefer do it with the bios,but as I can see in the manual of our board you don't have this posibity, try easytune, but the one I have try with easytune was able to set it manually in the bios......
Old April 17, 2009, 02:20 PM
stoanee's Avatar
OC in bios is the best, use the power of Google........
heatware
Old April 17, 2009, 02:54 PM
Advanced features = <CTRL> <F1> in gigabyte bios.
Old April 17, 2009, 02:58 PM
geokilla's Avatar
Update it to the latest BIOS and you may not have to use the CTRL + F1
Old April 18, 2009, 06:32 PM
Hey, so I got the newest version of the BIOS and you still have to use CTRL + F1, not a problem or anything, so I can set the mutliplier and FSB now, which is good, BUT, it seems on this motherboard being a low end m-atx board... It doesn't support voltage settings other than on the memory i think, it wont even display the voltage.
So, i see there is pin mods for am2, and I can't get Easy Tune to work, it works but the Overclocking is greyed out for some reason i have no idea...
I can overclock it, but without voltage settings i wont be able to get very far... any ideas?
Old April 18, 2009, 06:33 PM
geokilla's Avatar
Get as far as you can and then call it a day. That's about it unless you want to try to mod the board.
Old April 22, 2009, 06:05 PM
RONEDOGG's Avatar
to be honest bro to save yourself ALOT of headache just buy a new motherboard with more overclocking features.
i recomend asus they have never let me down yet :)
my first overclocking board i had was a gigabyte ds3l or osmthing and i loved it. then i picked up a p5n-t deluxe and i have bought only asus since
cheers and good luck
Get off my lawn boy
i need help finding a program EaGle1337 Off Topic 0 January 26, 2009 05:37 PM
EVGA step-up program, yes or no? dboulay79 Video Cards 3 February 9, 2008 06:11 PM
How to overclock an amd athlon 2x 5600 Dizodax CPU's and Motherboards 20 November 1, 2007 08:39 PM
program Rapid-X O/S's, Drivers & General Software 8 September 3, 2007 06:13 PM
CS:S ti normal program Long John Silver Gaming 5 June 21, 2007 07:32 PM
