Old April 6, 2009, 05:35 AM
somecanadianguy's Avatar
Default EasyTune 6... any good for OC?
I just built my system...
Motherboard comes with EasyTune 6 and I'm wondering if anyone would recommend usind it? If I try their boost buttons is it easy to go back to what I had, or will I have to manually reset stuff? I don't really know how to OC (though I'm starting to learn)...
Old April 6, 2009, 05:55 AM
misterlarry's Avatar
I tried Easytune 6 with my mobo when I built this rig. While it will work and is certainly easier, I liked being able to manually set parameters in the bios. Then when I'm monitoring them (HWmonitor), I can see normal voltage lag and discrepancies or possible problems before they cost me a board or chip. I preferred setting everything manually. JMHO.
Asus Z97-A - Intel i7 4790K @ 4.0 GHz - Corsair H80 CPU Cooler- 4x8 GB G.Skill Ares DDR3 2400 - EVGA GTX960 4GB
1x240 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 1X2 TB Western Digital Green - Pioneer DVR-212D - Antec P182 - Rosewill Photon 850 - 2X24" Acer G246HYL - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old April 6, 2009, 05:59 AM
CanadaRox's Avatar
I find its useful for testing overclocking, but when I put my settings in for 24/7 I do it through the BIOS.
Project: Black and White
Old April 7, 2009, 08:24 AM
Thanks guys...
I'll try it out and see how it goes.
Eventually I'll be comfortable setting things manually.
Old April 7, 2009, 09:02 AM
rjbarker's Avatar
I cannot stress enough how important it is to "avoid" OC'ing Software and learn to understand / use the settings in the BIOS to OC. If you don't understand what the basic BIOS settings are for and leran to OC in the BIOS, you're setting yourself up for "issues"....Learn youur BIOS and OC in the Bios. Once you're comfortable with that then yes, at that point you can experiment with "Software"...The BIOS is the "heart" of your Mobo and OC'ing.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old April 7, 2009, 09:58 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Yeah make sure you know the basics at least because if you just start with software oc you will likely corrupt your os.
Old April 7, 2009, 10:01 AM
In any case avoid auto settings for voltages,
Cambridge,ON
MSI Z77 M Power/Bios17.12
[email protected]
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel Speed Demon x 2
Win 10 Pro x64
Old April 7, 2009, 10:28 AM
rjbarker's Avatar
Not necessarily, in many cases "Auto Voltages" for vCore will result in stable mild OC's, however, I have found that "Auto" will generally pump more voltage than what is required.
I do agree with you on that tyremanm, that setting manually is better.....and of course for pushing higher OC's manual voltage setting is the only way to go and finding that
sweet spot", not toom uch but just enough.
I know before I started playing with OC'ing I made sure to understand the principles and what my settings did in BIOS. I ONLY OC in BIOS!
MARK 11: 32.530
Old April 7, 2009, 10:38 AM
Yeah same here, I don't have easy tune loaded here period.
I always set manually in cmos.
I mentioned about not using auto voltages only because I don't know what people are doing out there with new toys didn't want it to ramp up with another change
Cambridge,ON
[email protected]
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Win 10 Pro x64
Old April 7, 2009, 10:46 AM
Eldonko's Avatar
I would avoid auto voltages on giga boards. It will put VTT and PLL voltages at dangerous levels, 1.60v and 1.85v with a mild oc. If you are ok with this then go ahead, but I just wanted to give some warning.
good 1 day/bad another? frosty Water Cooling 6 November 3, 2008 12:35 PM
are they good? oksir Air Cooling 3 July 24, 2008 05:58 AM
good enough? rellish CPU's and Motherboards 9 March 19, 2008 02:22 PM
DAM Good PSU BALISTX Power Supplies 9 October 4, 2007 11:38 AM
this any good ? Jim RAM 3 May 29, 2007 01:34 PM
